[mapguide-users] Non-Administrator Users Can't Login
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Jul 29 03:41:27 EDT 2009
You can manage users from the MapAdmin:
http://localhost/mapguide/mapadmin/login.php
These users can then log in to MapGuide.
You need to set their permissions to resources
with a tool like Maestro or Studio.
There are no execute permissions in MapGuide, only read and write.
The permission system is not really documented, and works the opposite
of what I expected.
Search the mailing lists for details.
Regards, Kenneth Skovhede, GEOGRAF A/S
Bloozitis skrev:
> Hi Mauricio,
> Could you please be so kind as to explain, in detail, what these
> permissions are? Currently, I have set up a test account and a user
> account on the workstation with read and execute permissions.
> Unfortunately, there is no mention in the documentation of what
> permissions users need to access this.
> Cheers,
> Dennis
> *From:* Mauricio Villablanca (via Nabble)
> [mailto:ml-user+109705-477115064 at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3334926&i=0>]
> *Sent:* Thursday, July 23, 2009 1:08 AM
> *To:* Dennis Soper
> *Subject:* Re: [mapguide-users] Non-Administrator Users Can't Login
> You need to set the right permissions of the repository folders.
> *Bloozitis wrote:*
> Hi,
> I've created a test user, assigned it to a "mapauthors" group I
> created, which assigns the user to the "Authors" role. When I attempt
> to login as this user, I get an "Authentication failed. Please enter
> a valid username and password. The following message is in the error
> log:
> <2009-07-13T14:58:06> Map Admin 128.223.67.19 tester
> Error: Unauthorized access.
> StackTrace:
> - MgSiteServiceHandler.ProcessOperation line 83 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\site\SiteServiceHandler.cpp
> - MgOpEnumerateServers.Execute line 96 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\site\OpEnumerateServers.cpp
> - MgSecurityManager.Authenticate line 213 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\manager\SecurityManager.cpp
> Any ideas what I'm doing wrong? I'm running the bundled Apache on
> Windows 2003 Server with a PHP development environment.
> Cheers,
> Dennis
> View message @
> http://n2.nabble.com/Non-Administrator-Users-Can%27t-Login-tp3257838p3308151.html
> To unsubscribe from Non-Administrator Users Can't Login, click here.
> View this message in context: RE: [mapguide-users] Non-Administrator
> Users Can't Login
> <http://n2.nabble.com/Non-Administrator-Users-Can%27t-Login-tp3257838p3334926.html>
> Sent from the MapGuide Users mailing list archive
> <http://n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090729/3f609609/attachment.html
