[mapguide-users] mapguide examples won't display,
can't create new resources, possible permissions setup problem?
French, Emerson
Emerson.French at ARS.USDA.GOV
Tue Jul 28 11:39:29 EDT 2009
Hello all,
I'm very much new to MapGuide. After compilation from Subversion source
failed (I'm using Fedora 9; the Makefiles generated by ./configure
resulted in numerous errors and the like) I downloaded a copy of the
Live CD, loaded it into a virtual machine, and copied the MapGuide
installation to the server where I plan to run it. All the libraries I
need are in place, and apache and mgserver appear to start up without
trouble. However, I appear to have some permissions set wrong or
something. Although the map viewer itself will load in all the examples,
the actual maps do not load. An attempt to load a new Data connection in
Maestro fails with the error:
Unable to create the resource Library://{hex sequence} Error message:
System.Net.WebException: Error getting response stream (ReadDone2):
ReceiveFailure ---> System.Exception: at System.Net.WebConnection
Any clue on what the problem is here? Any help would be greatly
appreciated.
Thanks,
Emerson French
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090728/2fc847c9/attachment.html
