[mapguide-users] Adding layer to runtimemap
Gunter Becker gunter.becker at csogis.de
Thu Jul 30 05:07:12 EDT 2009
OK, initializing the RuntimeMapLayer works but after saving back the modified
map to the Session-Repository the MgServer service is terminated. I have to
restart the service and also the IIS.
When I debug my application I relize an error on the
RuntimeMapLayer.IDs-property:
     'runMapLayer.IDs' threw an exception of type 'System.Exception'
     Message: Cannot reload ID's because the layers parent is not set
     StackTrace: at
OSGeo.MapGuide.MaestroAPI.RuntimeClasses.RuntimeMapLayer.FindResourceIDs()
                      at
OSGeo.MapGuide.MaestroAPI.RuntimeClasses.RuntimeMapLayer.get_IDs()"
So I've looked at the parent-property of the RuntimeMapLayer and it is set
to "null". Does this cause the problem? The parent-property is of type
MapDefinition and I'm wondering why I need a reference to the MapDefinition
at all?
What ist the best practice, when I want to add a new layer at runtime from
an exisiting MapDefinition in Library-Repository and which methode should I
use
Gunter
Gunter Becker wrote:
> Great, it works for me.
> Thank you Kenneth
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Indeed it is.
>> You need to change line 1545 of the file
>> MaestroAPI/Generated/LayerDefinition-1.3.0.cs
>> http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/MaestroAPI/Generated/LayerDefinition-1.2.0.cs#L1545
>> Before:
>> public static readonly string SchemaName = "LayerDefinition-1.2.0.xsd";
>> After:
>> public static readonly string SchemaName = "LayerDefinition-1.3.0.xsd";
>> I will put that fix in trunk, but for now you can use it if you compile
>> yourself.
>> This also means that you cannot save 1.3.0 layers from Maestro.
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> Gunter Becker skrev:
>>> Hi,
>>> I'm trying to add a layer to the runtimemap using the MaestroAPI:
>>>    MapLayerType layer = layerArray[layerName];
>>>    RuntimeMapLayer runMapLayer = new RuntimeMapLayer(layer);
>>>    runMap.Layers.Add(runMapLayer);
>>> On creating the RuntimeMapLayer I get the following Error:
>>>    error in XML document (2,117)
>>> I suppose it's the same error like in this
>>> http://n2.nabble.com/Can%27t-open-LayerDefinition-with-maestro-tt3276282.html#a3276282
>>> thread  and therefore I build the MaestroAPI.dll
>>> from trunk as mentioned there. But the error still remains.
>>> Any idea?
>>> Thanks, Gunter
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Adding-layer-to-runtimemap-tp3352200p3355139.html
