[mapguide-users] Adding layer to runtimemap
Gunter Becker
gunter.becker at csogis.de
Thu Jul 30 03:18:10 EDT 2009
Great, it works for me.
Thank you Kenneth
Kenneth Skovhede, GEOGRAF A/S wrote:
> Indeed it is.
> You need to change line 1545 of the file
> MaestroAPI/Generated/LayerDefinition-1.3.0.cs
> http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/MaestroAPI/Generated/LayerDefinition-1.2.0.cs#L1545
> Before:
> public static readonly string SchemaName = "LayerDefinition-1.2.0.xsd";
> After:
> public static readonly string SchemaName = "LayerDefinition-1.3.0.xsd";
> I will put that fix in trunk, but for now you can use it if you compile
> yourself.
> This also means that you cannot save 1.3.0 layers from Maestro.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Gunter Becker skrev:
>> Hi,
>> I'm trying to add a layer to the runtimemap using the MaestroAPI:
>> MapLayerType layer = layerArray[layerName];
>> RuntimeMapLayer runMapLayer = new RuntimeMapLayer(layer);
>> runMap.Layers.Add(runMapLayer);
>> On creating the RuntimeMapLayer I get the following Error:
>> error in XML document (2,117)
>> I suppose it's the same error like in this
>> http://n2.nabble.com/Can%27t-open-LayerDefinition-with-maestro-tt3276282.html#a3276282
>> thread and therefore I build the MaestroAPI.dll
>> from trunk as mentioned there. But the error still remains.
>> Any idea?
>> Thanks, Gunter
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Adding-layer-to-runtimemap-tp3352200p3354658.html
