[mapguide-users] 2.1 installation problem
Andrew DeMerchant andrew.demerchant at gemtec.ca
Mon Jun 1 15:09:34 EDT 2009
I was actually using the 8008 port - which is what the icon in my start
menu that got created by the installer used....
Andrew
On 6/1/2009 4:04 PM, Andy Morsell wrote:
> Since you're using an Apache install, it does not map to HTTP port 80
> by default so you will probably have to use http://localhost:8008 for
> your URL's. I suspect you're actually hitting your IIS server by using
> just http://localhost
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> 47° 46' N 116° 49' W
> www.SpatialGIS.com
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
> DeMerchant
> *Sent:* Monday, June 01, 2009 11:47 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] 2.1 installation problem
> I'm accessing it straight from the start menu - which seems to be
> using localhost (if that never works, perhaps someone should change
> the installer so it doesn't use it). I just tried using my ip, (and
> also tried 127.0.0.1 for the heck of it) but it didn't work
> either....same thing.
> Andrew
> On 6/1/2009 3:20 PM, Martin Morrison wrote:
> You are typing the full path rather than trying to browse the dir
> structure correct?  E.G. http://localhost/MapGuide/mapadmin/login.php
> You can no longer  go to http://localhost/MapGuide/mapadmin  This is a
> very good thing...
> Martin
> <mailto:mapguide-users-bounces at lists.osgeo.org>
> DeMerchant
> *Sent:* Monday, June 01, 2009 2:11 PM
> *Subject:* [mapguide-users] 2.1 installation problem
> I'm trying to install the 2.1 beta on a Windows 2000 virtual machine -
> I had had 2.0 on there with no problems (with IIS)...I uninstalled 2.0
> completely, then installed 2.1 with Apache - but when I try to access
> anything (MapAgent test pages, MapGuide site admin) I get a 403
> (access forbidden). I don't know Apache - any suggestions? I'm sure
> it's simple....but I could find anything online that was applicable.
> Andrew
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org  <mailto:mapguide-users at lists.osgeo.org>
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
