[mapguide-users] 2.1 installation problem
James Card James.Card at calcad.com
Mon Jun 1 20:51:10 EDT 2009
Aha! That explains why I was getting the same symptoms last week. Perhaps
we could persuade someone to add a note to the downloads page at
<http://mapguide.osgeo.org/download/releases/2.1.0>.
James Card
California CAD Solutions, Inc.
209-578-5580 - Voice
209-521-6493 - FAX
On Mon, 01 Jun 2009 17:08:43 -0700, Jackie Ng <jumpinjackie at gmail.com>
wrote:
> If you search msdn for this GetModuleHandleEx function, it will indicate
> that
> the minimum supported client is *Windows XP*, so this API was first
> introduced in Windows XP.
> In short, Windows 2000 is not supported.
> - Jackie
> Andrew DeMerchant wrote:
>> I did a search in httpd.conf, but didn't see any %MG occurrences. The
>> logs had a few php errors in them, but more interestingly, when I went
>> to restart the Apache server, it crashed (httd.exe crashed - with lots
>> of errors like "The procedure entry point GetModuleHandleExW could not
>> be located in the dynamic link library kernel32.dll". Here's my
>> error.log:
>> [Mon Jun 01 16:44:32 2009] [notice] Apache/2.2.4 (Win32) configured --
>> resuming normal operations
>> [Mon Jun 01 16:44:32 2009] [notice] Server built: Jan  9 2007 23:17:20
>> [Mon Jun 01 16:44:32 2009] [notice] Parent: Created child process 1428
>> [Mon Jun 01 16:44:32 2009] [notice] Disabled use of AcceptEx() WinSock2
>> API
>> PHP Warning:  PHP Startup: Unable to load dynamic library 'C:\\Program
>> Files\\OSGeo\\MapGuide\\Web\\Php\\ext\\php_MapGuideApiEnvConfig.dll' -
>> The specified procedure could not be found.\r\n in Unknown on line 0
>> [Mon Jun 01 16:44:34 2009] [notice] Child 1428: Child process is running
>> [Mon Jun 01 16:44:34 2009] [notice] Child 1428: Acquired the start
>> mutex.
>> [Mon Jun 01 16:44:34 2009] [notice] Child 1428: Starting 50 worker
>> threads.
>> [Mon Jun 01 16:44:34 2009] [notice] Child 1428: Listening on port 8008.
>> Andrew
>> On 6/1/2009 4:32 PM, Jason Birch wrote:
>>> Andew,
>>> Don't have a 2.1 installation handy, so locations may be a bit fuzzy...
>>> Could you please check your Apache installation to see if the mapping
>>> worked properly.  The configuration should be in:
>>> c:\program files\osgeo\mapguide\web\Apache2\conf\httpd.conf
>>> Have a look at it and see if there are any remaining %MG_
>>>  placeholders in there.   I'd be surprised if this was the case
>>> though; typically I think this causes the Apache service to fail to
>>> start, so you wouldn't get the HTTP errors at all.
>>> Next have a look in the web server logs.  I think they are in:
>>> c:\program files\osgeo\mapguide\web\Apache2\logs  and see if there's
>>> anything out of the ordinary in the access or error logs.
>>> Also, make sure that there are no leftovers from the 2.0 install, such
>>> as an invalid PHP location in the PATH or in the registry under
>>> HKLM\Software\PHP\5.2.5 (or something like that)
>>> Jason
>>> *From:* Andrew DeMerchant
>>> *Sent:* Monday, June 01, 2009 11:11 AM
>>> *To:* MapGuide Users Mail List
>>> *Subject:* [mapguide-users] 2.1 installation problem
>>> I'm trying to install the 2.1 beta on a Windows 2000 virtual machine -
>>> I had had 2.0 on there with no problems (with IIS)...I uninstalled 2.0
>>> completely, then installed 2.1 with Apache - but when I try to access
>>> anything (MapAgent test pages, MapGuide site admin) I get a 403
>>> (access forbidden). I don't know Apache - any suggestions? I'm sure
>>> it's simple....but I could find anything online that was applicable.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> 	*Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
