[mapguide-users] 2.1 installation problem
Jackie Ng
jumpinjackie at gmail.com
Mon Jun 1 20:08:43 EDT 2009
If you search msdn for this GetModuleHandleEx function, it will indicate that
the minimum supported client is *Windows XP*, so this API was first
introduced in Windows XP.
In short, Windows 2000 is not supported.
- Jackie
Andrew DeMerchant wrote:
> I did a search in httpd.conf, but didn't see any %MG occurrences. The
> logs had a few php errors in them, but more interestingly, when I went
> to restart the Apache server, it crashed (httd.exe crashed - with lots
> of errors like "The procedure entry point GetModuleHandleExW could not
> be located in the dynamic link library kernel32.dll". Here's my error.log:
> [Mon Jun 01 16:44:32 2009] [notice] Apache/2.2.4 (Win32) configured --
> resuming normal operations
> [Mon Jun 01 16:44:32 2009] [notice] Server built: Jan 9 2007 23:17:20
> [Mon Jun 01 16:44:32 2009] [notice] Parent: Created child process 1428
> [Mon Jun 01 16:44:32 2009] [notice] Disabled use of AcceptEx() WinSock2
> API
> PHP Warning: PHP Startup: Unable to load dynamic library 'C:\\Program
> Files\\OSGeo\\MapGuide\\Web\\Php\\ext\\php_MapGuideApiEnvConfig.dll' -
> The specified procedure could not be found.\r\n in Unknown on line 0
> [Mon Jun 01 16:44:34 2009] [notice] Child 1428: Child process is running
> [Mon Jun 01 16:44:34 2009] [notice] Child 1428: Acquired the start mutex.
> [Mon Jun 01 16:44:34 2009] [notice] Child 1428: Starting 50 worker
> threads.
> [Mon Jun 01 16:44:34 2009] [notice] Child 1428: Listening on port 8008.
> Andrew
> On 6/1/2009 4:32 PM, Jason Birch wrote:
>> Andew,
>> Don't have a 2.1 installation handy, so locations may be a bit fuzzy...
>> Could you please check your Apache installation to see if the mapping
>> worked properly. The configuration should be in:
>> c:\program files\osgeo\mapguide\web\Apache2\conf\httpd.conf
>> Have a look at it and see if there are any remaining %MG_
>> placeholders in there. I'd be surprised if this was the case
>> though; typically I think this causes the Apache service to fail to
>> start, so you wouldn't get the HTTP errors at all.
>> Next have a look in the web server logs. I think they are in:
>> c:\program files\osgeo\mapguide\web\Apache2\logs and see if there's
>> anything out of the ordinary in the access or error logs.
>> Also, make sure that there are no leftovers from the 2.0 install, such
>> as an invalid PHP location in the PATH or in the registry under
>> HKLM\Software\PHP\5.2.5 (or something like that)
>> Jason
>> *From:* Andrew DeMerchant
>> *Sent:* Monday, June 01, 2009 11:11 AM
>> *To:* MapGuide Users Mail List
>> *Subject:* [mapguide-users] 2.1 installation problem
>> I'm trying to install the 2.1 beta on a Windows 2000 virtual machine -
>> I had had 2.0 on there with no problems (with IIS)...I uninstalled 2.0
>> completely, then installed 2.1 with Apache - but when I try to access
>> anything (MapAgent test pages, MapGuide site admin) I get a 403
>> (access forbidden). I don't know Apache - any suggestions? I'm sure
>> it's simple....but I could find anything online that was applicable.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
View this message in context: http://n2.nabble.com/How-to-Save-Redline-Object-on-a-new-Layer-tp2992274p3009575.html
