[mapguide-users] 2.1 installation problem
Andrew DeMerchant andrew.demerchant at gemtec.ca
Mon Jun 1 15:45:16 EDT 2009
I did a search in httpd.conf, but didn't see any %MG occurrences. The
logs had a few php errors in them, but more interestingly, when I went
to restart the Apache server, it crashed (httd.exe crashed - with lots
of errors like "The procedure entry point GetModuleHandleExW could not
be located in the dynamic link library kernel32.dll". Here's my error.log:
[Mon Jun 01 16:44:32 2009] [notice] Apache/2.2.4 (Win32) configured --
resuming normal operations
[Mon Jun 01 16:44:32 2009] [notice] Server built: Jan  9 2007 23:17:20
[Mon Jun 01 16:44:32 2009] [notice] Parent: Created child process 1428
[Mon Jun 01 16:44:32 2009] [notice] Disabled use of AcceptEx() WinSock2 API
PHP Warning:  PHP Startup: Unable to load dynamic library 'C:\\Program
Files\\OSGeo\\MapGuide\\Web\\Php\\ext\\php_MapGuideApiEnvConfig.dll' -
The specified procedure could not be found.\r\n in Unknown on line 0
[Mon Jun 01 16:44:34 2009] [notice] Child 1428: Child process is running
[Mon Jun 01 16:44:34 2009] [notice] Child 1428: Acquired the start mutex.
[Mon Jun 01 16:44:34 2009] [notice] Child 1428: Starting 50 worker threads.
[Mon Jun 01 16:44:34 2009] [notice] Child 1428: Listening on port 8008.
Andrew
On 6/1/2009 4:32 PM, Jason Birch wrote:
> Andew,
> Don't have a 2.1 installation handy, so locations may be a bit fuzzy...
> Could you please check your Apache installation to see if the mapping
> worked properly.  The configuration should be in:
> c:\program files\osgeo\mapguide\web\Apache2\conf\httpd.conf
> Have a look at it and see if there are any remaining %MG_
>  placeholders in there.   I'd be surprised if this was the case
> though; typically I think this causes the Apache service to fail to
> start, so you wouldn't get the HTTP errors at all.
> Next have a look in the web server logs.  I think they are in:
> c:\program files\osgeo\mapguide\web\Apache2\logs  and see if there's
> anything out of the ordinary in the access or error logs.
> Also, make sure that there are no leftovers from the 2.0 install, such
> as an invalid PHP location in the PATH or in the registry under
> HKLM\Software\PHP\5.2.5 (or something like that)
> Jason
> *From:* Andrew DeMerchant
> *Sent:* Monday, June 01, 2009 11:11 AM
> *To:* MapGuide Users Mail List
> *Subject:* [mapguide-users] 2.1 installation problem
> I'm trying to install the 2.1 beta on a Windows 2000 virtual machine -
> I had had 2.0 on there with no problems (with IIS)...I uninstalled 2.0
> completely, then installed 2.1 with Apache - but when I try to access
> anything (MapAgent test pages, MapGuide site admin) I get a 403
> (access forbidden). I don't know Apache - any suggestions? I'm sure
> it's simple....but I could find anything online that was applicable.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
	*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
