[mapguide-users] 2.1 installation problem
Jackie Ng
jumpinjackie at gmail.com
Mon Jun 1 23:37:10 EDT 2009
Not quite, from your observations it seems the main offender is the
php_MapGuideApiEnvConfig.dll
Looking at the source-code, you'll see the GetModuleHandleEx() API I
mentioned being used.
http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.cpp
Now the purpose of the php_MapGuideApiEnvConfig.dll is to resolve multiple
different versions of php installed on the same system.
If the only version of PHP you're using is the one that comes with MapGuide,
then you can remove the reference to php_MapGuideApiEnvConfig.dll in the
php.ini and see if MapGuide is operational.
If so, then we just need to see if a Windows 2000 equivalent API exists
(GetModuleHandle???) that does the same thing.
- Jackie
Andrew DeMerchant wrote:
> So suddenly with MapGuide 2.1, we've lost Win2k support?? Well that
> seriously sucks, if it's true. That means I'm stuck with 2.0 and on a
> dead end street for the unforeseeable future. Is that correct?
> Andrew
> James Card wrote:
>> Aha! That explains why I was getting the same symptoms last week.
>> Perhaps we could persuade someone to add a note to the downloads page
>> at <http://mapguide.osgeo.org/download/releases/2.1.0>.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/How-to-Save-Redline-Object-on-a-new-Layer-tp2992274p3010274.html
