[mapguide-users] 2.1 installation problem
Jackie Ng jumpinjackie at gmail.com
Tue Jun 2 09:07:52 EDT 2009
Ok I've just done a clean install on a Windows 2000 VM with a trunk build
installer (roughly the same as the 2.1 beta) using Apache/PHP and I have a
functioning server and web extensions.
I also got the same problems with php_MapGuideApiEnvConfig.dll in my error
logs.
So there must be some other factor at play here.
Have you tried running both the MapGuide Server and/or Apache interactively?
Please note that I also installed the Windows 2000 Update Rollup package as
well. I don't know if this makes a difference.
- Jackie
Jackie Ng wrote:
> Not quite, from your observations it seems the main offender is the
> Looking at the source-code, you'll see the GetModuleHandleEx() API I
> mentioned being used.
> http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.cpp
> Now the purpose of the php_MapGuideApiEnvConfig.dll is to resolve multiple
> different versions of php installed on the same system.
> If the only version of PHP you're using is the one that comes with
> MapGuide, then you can remove the reference to
> php_MapGuideApiEnvConfig.dll in the php.ini and see if MapGuide is
> operational.
> If so, then we just need to see if a Windows 2000 equivalent API exists
> (GetModuleHandle???) that does the same thing.
> - Jackie
> Andrew DeMerchant wrote:
>> So suddenly with MapGuide 2.1, we've lost Win2k support?? Well that
>> seriously sucks, if it's true. That means I'm stuck with 2.0 and on a
>> dead end street for the unforeseeable future. Is that correct?
>> Andrew
>> James Card wrote:
>>> Aha! That explains why I was getting the same symptoms last week.
>>> Perhaps we could persuade someone to add a note to the downloads page
>>> at <http://mapguide.osgeo.org/download/releases/2.1.0>.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/How-to-Save-Redline-Object-on-a-new-Layer-tp2992274p3011919.html
