[mapguide-users] Georaster and MapGuide Open Source or Enterprise
Haris Kurtagic haris at sl-king.com
Wed Jun 3 05:05:09 EDT 2009
Marius,
I was doing some test work on provider and Georaster (when we had
potential customer) but never implemented. Main reason I moved to OCI
interface is to be able to work with XML's in oracle (needed for
Georaster). We haven't implemented it because with customers/projects we
came across there was no need for Oracle Georaster yet. Basically I
don't even have real use case to try it out.
If you are using current version of King.Oracle you should be aware of
problem with how MapGuide uses readers returned from provider.
Problem with MG becomes obvious when provider allows multiple command to
be executed over same Oracle connection (which current provider allows).
It made MG very unstable with concurrent access.
I will soon publish new release of provider (it is just workaround for
what I believe is MG issue). In couple of our projects, MG is stable
now.
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of marius.360
Sent: Wednesday, June 03, 2009 10:23 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Georaster and MapGuide Open Source or
Enterprise
Hi Haris,
We have an interest in using Oracle Georaster, and I am busy
investigating
suitable platforms for using it. Have you perhaps looked further into
integrating georaster into the King.Oracle provider? We currently have
many
systems running MGOS & Oracle spatial data using the King.Oracle
provider
and we would benefit greatly from georaster being supported by
King.Oracle.
Regards,
Marius
Haris Kurtagic wrote:
> Latest GDAL version (I believe 1.6) have an Oracle GeoRaster support.
I
> haven't tried it.
> I was thinking of adding support for GeoRaster in King.Oracle provider
> but we haven't run into usage of Oracle GeoRaster, yet.
> You are using Oracle GeoRaster ?
> Haris
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of BGUILLO
> Sent: Tuesday, March 24, 2009 10:48 AM
> Subject: [mapguide-users] Georaster and MapGuide Open Source or
> Enterprise
> Hi all,
> I wonder if there's in MapGuide Open Source or Enterprise a provider
> permitting to use the Oracle's format Georaster .
> Thanks
> Bianca
http://n2.nabble.com/Georaster-and-MapGuide-Open-Source-or-Enterprise-tp
> 2525607p2525607.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
2525607p3016939.html
