[mapguide-users] Georaster and MapGuide Open Source or Enterprise
marius.360 marius at osssa.co.za
Wed Jun 3 05:58:41 EDT 2009
I am looking forward to your new release provider, as I still encounter
instability, although it is greatly improved from earlier versions.
Marius
Haris Kurtagic wrote:
> Marius,
> I was doing some test work on provider and Georaster (when we had
> potential customer) but never implemented. Main reason I moved to OCI
> interface is to be able to work with XML's in oracle (needed for
> Georaster). We haven't implemented it because with customers/projects we
> came across there was no need for Oracle Georaster yet. Basically I
> don't even have real use case to try it out.
> If you are using current version of King.Oracle you should be aware of
> problem with how MapGuide uses readers returned from provider.
> Problem with MG becomes obvious when provider allows multiple command to
> be executed over same Oracle connection (which current provider allows).
> It made MG very unstable with concurrent access.
> I will soon publish new release of provider (it is just workaround for
> what I believe is MG issue). In couple of our projects, MG is stable
> now.
> Haris
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of marius.360
> Sent: Wednesday, June 03, 2009 10:23 AM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Georaster and MapGuide Open Source or
> Enterprise
> Hi Haris,
> We have an interest in using Oracle Georaster, and I am busy
> investigating
> suitable platforms for using it. Have you perhaps looked further into
> integrating georaster into the King.Oracle provider? We currently have
> many
> systems running MGOS & Oracle spatial data using the King.Oracle
> provider
> and we would benefit greatly from georaster being supported by
> King.Oracle.
> Regards,
> Marius
>> Latest GDAL version (I believe 1.6) have an Oracle GeoRaster support.
> I
>> haven't tried it.
>> I was thinking of adding support for GeoRaster in King.Oracle provider
>> but we haven't run into usage of Oracle GeoRaster, yet.
>> You are using Oracle GeoRaster ?
>> Haris
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of BGUILLO
>> Sent: Tuesday, March 24, 2009 10:48 AM
>> Subject: [mapguide-users] Georaster and MapGuide Open Source or
>> Enterprise
>> Hi all,
>> I wonder if there's in MapGuide Open Source or Enterprise a provider
>> permitting to use the Oracle's format Georaster .
>> Thanks
>> Bianca
>> View this message in context:
> http://n2.nabble.com/Georaster-and-MapGuide-Open-Source-or-Enterprise-tp
>> 2525607p2525607.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> 2525607p3016939.html
View this message in context: http://n2.nabble.com/Georaster-and-MapGuide-Open-Source-or-Enterprise-tp2525607p3017276.html
