[mapguide-users] prob with GetSelectionXml()
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Jun 4 02:45:16 EDT 2009
No need to double or triple post.
You answer can be found here:
http://sandbox.mapguide.com/index.php/Change_Selection_Color_Setting
or here:
http://www.jasonbirch.com/nodes/2008/12/02/213/changing-selection-colour-in-mapguide-ajax-viewer/
Regards, Kenneth Skovhede, GEOGRAF A/S
saloua wakrim skrev:
> hi kenneth ! when we select object on map or (selection) mapguide
> marks it with blue color (with some transparency) who knows the code
> of this color? if we want use it for example as foreground to draw
> layer what is the code wich allow that, thanks for all in advance
> 2009/5/28 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk
> <mailto:ks at geograf.dk>>
>     Its the runtime layer's ID, which is a guid string, and changes
>     for each invocation of the map.
>     (eg, you can't save it and use it in another session).
>     Selection xml looks like this:
>     <Layer id="layer guid">
>      <Class id="feature class">
>        <ID>base64 encoded primary key value</ID>
>      </Class>
>     </Layer>
>     You can have multiple <Layer> tags, multiple <Class> tags, and
>     multiple <ID> tags.
>     wakrimsaloua.wakrim at gmail.com
>     <mailto:wakrimsaloua.wakrim at gmail.com> skrev:
>         hi all! did you know what does" id" in <layer id=255.....>
>         returned by selection xml mean? cause when i got the
>         XmlSelection from map and i use it for getting layers it
>         contains i've error wich say that layers is nothing but the
>         selection is nt i've verifyed it the selection i got from map
>         is not empty but the layers are nothing, so i think that can
>         be caused by the "id" in <layer id=255.....> returned by the
>         selection if that mean the session for example cause me when i
>         create layer i do it with "library://......mapdefinition" and
>         not "Session//....mapdefinition" so i think that if the id on
>         <layer id=255.....> means the session used by user i think
>         that layer contained on selection won't be known, but i'm not
>         sure please if you have some idea tell it me, thanks a lot on
>         advance.
>         _______________________________________________
>         mapguide-users mailing list
>         mapguide-users at lists.osgeo.org
>         <mailto:mapguide-users at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/mapguide-users
>     mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090604/43a65a45/attachment.html
