[mapguide-users] prob with GetSelectionXml()
saloua wakrim wakrimsaloua.wakrim at gmail.com
Thu Jun 4 04:08:25 EDT 2009
hi! thanks a lot for your help, i didn't make attention that i posted you
same question many times, sorry
2009/6/4 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>
> No need to double or triple post.
> You answer can be found here:
> http://sandbox.mapguide.com/index.php/Change_Selection_Color_Setting
> or here:
> http://www.jasonbirch.com/nodes/2008/12/02/213/changing-selection-colour-in-mapguide-ajax-viewer/
> Regards, Kenneth Skovhede, GEOGRAF A/S
> saloua wakrim skrev:
>  hi kenneth ! when we select object on map or (selection) mapguide marks
> it with blue color (with some transparency) who knows the code of this
> color? if we want use it for example as foreground to draw layer what is the
> code wich allow that, thanks for all in advance
> 2009/5/28 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>
>> Its the runtime layer's ID, which is a guid string, and changes for each
>> invocation of the map.
>> (eg, you can't save it and use it in another session).
>> Selection xml looks like this:
>> <Layer id="layer guid">
>>  <Class id="feature class">
>>    <ID>base64 encoded primary key value</ID>
>>  </Class>
>> </Layer>
>> You can have multiple <Layer> tags, multiple <Class> tags, and multiple
>> <ID> tags.
>> wakrimsaloua.wakrim at gmail.com skrev:
>>> hi all! did you know what does" id" in <layer id=255.....> returned by
>>> selection xml mean? cause when i got the XmlSelection from map and i use it
>>> for getting layers it contains i've error wich say that layers is nothing
>>> but the selection is nt i've verifyed it the selection i got from map is not
>>> empty but the layers are nothing, so i think that can be caused by the "id"
>>> in <layer id=255.....> returned by the selection if that mean the session
>>> for example cause me when i create layer i do it with
>>> "library://......mapdefinition" and not "Session//....mapdefinition" so i
>>> think that if the id on <layer id=255.....> means the session used by user i
>>> think that layer contained on selection won't be known, but i'm not sure
>>> please if you have some idea tell it me, thanks a lot on advance.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090604/863362f0/attachment.html
