[mapguide-users] prob with GetSelectionXml()
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Jun 8 03:06:53 EDT 2009
What version of MG are you using?
I have not used the AJAX viewer for some time, so I can't offer you any
advice.
If you get no responses, try posing a fresh question, as the current
subject will not
attract attention from the people likely to have the answer to this.
Regards, Kenneth Skovhede, GEOGRAF A/S
saloua wakrim skrev:
> hi kenneth! at first thanks a lot for your help, i've read the
> documentation you gove me and tried to apply it for changing selection
> color : format of my "ajaxmappane.templ" (or function wich concerning
> me) is
> function RequestMapImage(reqId)
> url = webAgent +
> "?OPERATION=GETDYNAMICMAPOVERLAYIMAGE&FORMAT=PNG&VERSION=1.0.0&SESSION="
> + sessionId + "&MAPNAME=" + encodeComponent(mapName) + "&SEQ=" +
> Math.random()
> document.getElementById("overlay").innerHTML =
> '<img class="mapImage" name="' + reqId + '" id="mapImage"
> src="' + url + '" width=' + mapDevW + ' height=' + mapDevH + '
> border=0 vspace=0 hspace=0 style="visibility: hidden; width: ' +
> mapDevW + 'px; height: ' + mapDevH + 'px;" onload="return
> OnMapOverlayImageLoaded(event)">';
> i've tried to modify it by adding:
> .....Math.random()*+ "&BEHAVIOR=7&SELECTIONCOLOR=FF5300FF"*; As
> documentation says, and when i try after to get my map on ajaxviewer
> it's not loaded the ajax viewer is loaded but page not contains my
> map!!!! i've changed version too (as documentation you sent me)
> VERSION=1.0.0 to VERSION=*2.0.0 but it doesn't give good result, if
> you can explain me why?? thanks in advance*
> 2009/6/4 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk
> <mailto:ks at geograf.dk>>
> No need to double or triple post.
> You answer can be found here:
> http://sandbox.mapguide.com/index.php/Change_Selection_Color_Setting
> or here:
> http://www.jasonbirch.com/nodes/2008/12/02/213/changing-selection-colour-in-mapguide-ajax-viewer/
>> hi kenneth ! when we select object on map or (selection) mapguide
>> marks it with blue color (with some transparency) who knows the
>> code of this color? if we want use it for example as foreground
>> to draw layer what is the code wich allow that, thanks for all in
>> advance
>> 2009/5/28 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk
>> Its the runtime layer's ID, which is a guid string, and
>> changes for each invocation of the map.
>> (eg, you can't save it and use it in another session).
>> Selection xml looks like this:
>> <Layer id="layer guid">
>> <Class id="feature class">
>> <ID>base64 encoded primary key value</ID>
>> </Class>
>> </Layer>
>> You can have multiple <Layer> tags, multiple <Class> tags,
>> and multiple <ID> tags.
>> wakrimsaloua.wakrim at gmail.com
>> <mailto:wakrimsaloua.wakrim at gmail.com> skrev:
>> hi all! did you know what does" id" in <layer
>> id=255.....> returned by selection xml mean? cause when i
>> got the XmlSelection from map and i use it for getting
>> layers it contains i've error wich say that layers is
>> nothing but the selection is nt i've verifyed it the
>> selection i got from map is not empty but the layers are
>> nothing, so i think that can be caused by the "id" in
>> <layer id=255.....> returned by the selection if that
>> mean the session for example cause me when i create layer
>> i do it with "library://......mapdefinition" and not
>> "Session//....mapdefinition" so i think that if the id on
>> <layer id=255.....> means the session used by user i
>> think that layer contained on selection won't be known,
>> but i'm not sure please if you have some idea tell it me,
>> thanks a lot on advance.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> <mailto:mapguide-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> _______________________________________________ mapguide-users
>> mailing list mapguide-users at lists.osgeo.org
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090608/22cc59a4/attachment.html
