[mapguide-users] prob with GetSelectionXml()
saloua wakrim wakrimsaloua.wakrim at gmail.com
Mon Jun 8 04:11:01 EDT 2009
ok thanks,i'll try do it and restart mapguide server,thanks any way
2009/6/8 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>
> What version of MG are you using?
> I have not used the AJAX viewer for some time, so I can't offer you any
> advice.
> If you get no responses, try posing a fresh question, as the current
> subject will not
> attract attention from the people likely to have the answer to this.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> saloua wakrim skrev:
>   hi kenneth! at first thanks a lot for your help, i've read the
> documentation you gove me and tried to apply it for changing selection color
> : format of my "ajaxmappane.templ" (or function wich concerning me) is
> function RequestMapImage(reqId)
>     url = webAgent +
> "?OPERATION=GETDYNAMICMAPOVERLAYIMAGE&FORMAT=PNG&VERSION=1.0.0&SESSION=" +
> sessionId + "&MAPNAME=" + encodeComponent(mapName) + "&SEQ=" + Math.random()
>     document.getElementById("overlay").innerHTML =
>             '<img class="mapImage" name="' + reqId + '" id="mapImage"
> src="' + url + '" width=' + mapDevW + ' height=' + mapDevH + ' border=0
> vspace=0 hspace=0 style="visibility: hidden; width: ' + mapDevW + 'px;
> height: ' + mapDevH + 'px;" onload="return
> OnMapOverlayImageLoaded(event)">';
> i've tried to modify it by adding:
> .....Math.random()*+ "&BEHAVIOR=7&SELECTIONCOLOR=FF5300FF"*; As
> documentation says, and when i try after to get my map on ajaxviewer it's
> not loaded the ajax viewer is loaded but page not contains my map!!!! i've
> changed version too (as documentation you sent me)
> VERSION=1.0.0 to VERSION=*2.0.0 but it doesn't give good result, if you
> can explain me why?? thanks in advance*
> 2009/6/4 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>
>> No need to double or triple post.
>> You answer can be found here:
>> http://sandbox.mapguide.com/index.php/Change_Selection_Color_Setting
>> or here:
>> http://www.jasonbirch.com/nodes/2008/12/02/213/changing-selection-colour-in-mapguide-ajax-viewer/
>>  hi kenneth ! when we select object on map or (selection) mapguide marks
>> it with blue color (with some transparency) who knows the code of this
>> color? if we want use it for example as foreground to draw layer what is the
>> code wich allow that, thanks for all in advance
>> 2009/5/28 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>
>>> Its the runtime layer's ID, which is a guid string, and changes for each
>>> invocation of the map.
>>> (eg, you can't save it and use it in another session).
>>> Selection xml looks like this:
>>> <Layer id="layer guid">
>>>  <Class id="feature class">
>>>    <ID>base64 encoded primary key value</ID>
>>>  </Class>
>>> </Layer>
>>> You can have multiple <Layer> tags, multiple <Class> tags, and multiple
>>> <ID> tags.
>>> wakrimsaloua.wakrim at gmail.com skrev:
>>>> hi all! did you know what does" id" in <layer id=255.....> returned by
>>>> selection xml mean? cause when i got the XmlSelection from map and i use it
>>>> for getting layers it contains i've error wich say that layers is nothing
>>>> but the selection is nt i've verifyed it the selection i got from map is not
>>>> empty but the layers are nothing, so i think that can be caused by the "id"
>>>> in <layer id=255.....> returned by the selection if that mean the session
>>>> for example cause me when i create layer i do it with
>>>> "library://......mapdefinition" and not "Session//....mapdefinition" so i
>>>> think that if the id on <layer id=255.....> means the session used by user i
>>>> think that layer contained on selection won't be known, but i'm not sure
>>>> please if you have some idea tell it me, thanks a lot on advance.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090608/c0d12b34/attachment.html
