[mapguide-users] MapGuide v2.1 - Cannot select features on the map
miansi
AndreiSinelnikov at SierraSystems.com
Tue Jun 9 02:45:32 EDT 2009
Hello,
We are using MG v2.0.2 with SQL 2008.
I just install MG 2.1 and cannot resolve selection problem - layers drawn on
the map, but selection not working. I am using SRID 4269.
I believe it has something to do with coordinate system or scale, but I do
not know how to fix it:
http://n2.nabble.com/file/n3047742/coords.png
I tried coord system override on dataconnection and map:
http://n2.nabble.com/file/n3047742/_dataconnection.png
http://n2.nabble.com/file/n3047742/_map.png
My layer definition looks like this:
http://n2.nabble.com/file/n3047742/_layer.png
I see repeatable errors in Error.log, but cannot figure out what triggers
them:
<2009-06-08T23:38:24> 5584 Ajax Viewer ::1 Administrator
Error: Failed to stylize layer:
ENGINEEREDSTRUCTURE_ROAD_FEATURE_INTERSECTION
An exception occurred in FDO component.
RDBMS: [Microsoft][ODBC SQL Server Driver][SQL Server]A .NET
Framework error occurred during execution of user-defined routine or
aggregate "geometry":
System.FormatException: 24305: The Polygon input is not valid
because the ring does not have enough distinct points. Each ring of a
polygon must contain at least three distinct points.
at Microsoft.SqlServer.Types.Validator.Execute(Transition
transition)
at Microsoft.SqlServer.Types.ForwardingGeoDataSink.EndFigure()
at Micr
StackTrace:
- MgMappingUtil.StylizeLayers() line 776 file
c:\osgeo\mapguide_21\mgdev\server\src\services\mapping\MappingUtil.cpp
Error: Failed to stylize layer: ENGINEEREDSTRUCTURE_ROAD_LINE_ROADWAY
transition)
at Micr
StackTrace:
View this message in context: http://n2.nabble.com/MapGuide-v2.1---Cannot-select-features-on-the-map-tp3047742p3047742.html
