[mapguide-users] MapGuide v2.1 - Cannot select features on the map
Zac Spitzer zac.spitzer at gmail.com
Tue Jun 9 02:48:11 EDT 2009
the error message is rather clear, it looks like your data is corrupt?
On Tue, Jun 9, 2009 at 4:45 PM,
miansi<AndreiSinelnikov at sierrasystems.com> wrote:
> Hello,
> We are using MG v2.0.2 with SQL 2008.
> I just install MG 2.1 and cannot resolve selection problem - layers drawn on
> the map, but selection not working. I am using SRID 4269.
> I believe it has something to do with coordinate system or scale, but I do
> not know how to fix it:
> http://n2.nabble.com/file/n3047742/coords.png
> I tried coord system override on dataconnection and map:
> http://n2.nabble.com/file/n3047742/_dataconnection.png
> http://n2.nabble.com/file/n3047742/_map.png
> My layer definition looks like this:
> http://n2.nabble.com/file/n3047742/_layer.png
> I see repeatable errors in Error.log, but cannot figure out what triggers
> them:
> <2009-06-08T23:38:24>   5584    Ajax Viewer     ::1     Administrator
>  Error: Failed to stylize layer:
> ENGINEEREDSTRUCTURE_ROAD_FEATURE_INTERSECTION
>        An exception occurred in FDO component.
>        RDBMS: [Microsoft][ODBC SQL Server Driver][SQL Server]A .NET
> Framework error occurred during execution of user-defined routine or
> aggregate "geometry":
>        System.FormatException: 24305: The Polygon input is not valid
> because the ring does not have enough distinct points. Each ring of a
> polygon must contain at least three distinct points.
>           at Microsoft.SqlServer.Types.Validator.Execute(Transition
> transition)
>           at Microsoft.SqlServer.Types.ForwardingGeoDataSink.EndFigure()
>           at Micr
>  StackTrace:
>  - MgMappingUtil.StylizeLayers() line 776 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\mapping\MappingUtil.cpp
>  Error: Failed to stylize layer: ENGINEEREDSTRUCTURE_ROAD_LINE_ROADWAY
> transition)
>           at Micr
>  StackTrace:
> View this message in context: http://n2.nabble.com/MapGuide-v2.1---Cannot-select-features-on-the-map-tp3047742p3047742.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
