[mapguide-users] MapGuide v2.1 - Cannot select features on the
map
Zac Spitzer
zac.spitzer at gmail.com
Tue Jun 9 02:53:54 EDT 2009
there's probably been a change in the fdo provider since 2.0.2
end of the day, your getting a very clear error from your
database layer via FDO, as such it doesn't seem to be a
mapguide issue per se
whats the WKT for the geom causing the error?
z
On Tue, Jun 9, 2009 at 4:50 PM,
miansi<AndreiSinelnikov at sierrasystems.com> wrote:
> Exactly the same data works fine in MG v2.0.2
> From: zspitzer (via Nabble) [mailto:ml-user+1569-572190233 at ...]
> Sent: Tuesday, June 09, 2009 12:49 AM
> To: Sinelnikov, Andrei
> Subject: Re: [mapguide-users] MapGuide v2.1 - Cannot select features on the
> map
> the error message is rather clear, it looks like your data is corrupt?
> On Tue, Jun 9, 2009 at 4:45 PM,
> miansi<AndreiSinelnikov at ...> wrote:
>> Hello,
>> We are using MG v2.0.2 with SQL 2008.
>> I just install MG 2.1 and cannot resolve selection problem - layers drawn
>> on
>> the map, but selection not working. I am using SRID 4269.
>> I believe it has something to do with coordinate system or scale, but I do
>> not know how to fix it:
>> http://n2.nabble.com/file/n3047742/coords.png
>> I tried coord system override on dataconnection and map:
>> http://n2.nabble.com/file/n3047742/_dataconnection.png
>> http://n2.nabble.com/file/n3047742/_map.png
>> My layer definition looks like this:
>> http://n2.nabble.com/file/n3047742/_layer.png
>> I see repeatable errors in Error.log, but cannot figure out what triggers
>> them:
>> <2009-06-08T23:38:24> 5584 Ajax Viewer ::1 Administrator
>> Error: Failed to stylize layer:
>> ENGINEEREDSTRUCTURE_ROAD_FEATURE_INTERSECTION
>> An exception occurred in FDO component.
>> RDBMS: [Microsoft][ODBC SQL Server Driver][SQL Server]A .NET
>> Framework error occurred during execution of user-defined routine or
>> aggregate "geometry":
>> System.FormatException: 24305: The Polygon input is not valid
>> because the ring does not have enough distinct points. Each ring of a
>> polygon must contain at least three distinct points.
>> at Microsoft.SqlServer.Types.Validator.Execute(Transition
>> transition)
>> at Microsoft.SqlServer.Types.ForwardingGeoDataSink.EndFigure()
>> at Micr
>> StackTrace:
>> - MgMappingUtil.StylizeLayers() line 776 file
>> c:\osgeo\mapguide_21\mgdev\server\src\services\mapping\MappingUtil.cpp
>> Error: Failed to stylize layer: ENGINEEREDSTRUCTURE_ROAD_LINE_ROADWAY
>> transition)
>> at Micr
>> StackTrace:
>> View this message in context:
>> http://n2.nabble.com/MapGuide-v2.1---Cannot-select-features-on-the-map-tp3047742p3047742.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at ...
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
> This email is a reply to your post @
> http://n2.nabble.com/MapGuide-v2.1---Cannot-select-features-on-the-map-tp3047742p3047752.html
> You can reply by email or by visting the link above.
> ----Notice Regarding Confidentiality----
> This email, including any and all attachments, (this “Email”) is intended
> only for the party to whom it is addressed and may contain information that
> is confidential or privileged. Sierra Systems Group Inc. and its affiliates
> accept no responsibility for any loss or damage suffered by any person
> resulting from any unauthorized use of or reliance upon this Email. If you
> are not the intended recipient, you are hereby notified that any
> dissemination, copying or other use of this Email is prohibited. Please
> notify us of the error in communication by return email and destroy all
> copies of this Email. Thank you.
> View this message in context: RE: [mapguide-users] MapGuide v2.1 - Cannot
> select features on the map
> mapguide-users at lists.osgeo.org
Zac Spitzer -
+61 405 847 168
