[mapguide-users] Dwg to shape
Martin Morrison
martin.morrison at edsi.com
Wed Jun 10 07:58:20 EDT 2009
You can also buy AutoCAD Map will export a dwg to shape.
Martin
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: Wednesday, June 10, 2009 4:00 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Dwg to shape
AFAIK, the DWG is a proprietary format.
There exists an OpenDWG alliance with a DWG library,
but calling it "open source" is incorrect in my opinion.
It is non-trivial to understand the DWG file format,
especially since the 2004 version came out.
I don't think any open source projects support DWG.
If you have access to AutoCAD or similar,
try exporting it as DXF as that is an open format:
http://en.wikipedia.org/wiki/AutoCAD_DXF
Your easiest bet is to purchase MapGuide Studio which
can read in DWG files, and store them as SDF's (I think?).
You can then use FDOToolbox to convert them to SHP.
However, the current license model requires you to purchase
MGE to get a copy of Studio, so that may be too much.
Otherwise you can look at FME Universal Translator,
which is capable of converting just about anything:
http://docs.safe.com/fme/html/UT/welcome_to_fme_universal_translator.htm
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> iam using mapguide opensource 2.0
> is there are any mapguide opensource dlls for converting drawing file to
> shape files and vice versa................
> can anybody worked on this criteria......................
> Regards,
> Padmini.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
