[mapguide-users] Conversion of Drawing file to Shape file
Horness, Tom thorness at ci.sheboygan.wi.us
Wed Jun 10 11:55:11 EDT 2009
Hello
>From inside Autodesk Map & Civil 3D, command "Mapexport" allows you to export to Shape, Coverage and a number of other formats, directly. Take the time to select data attributes in the Source fields and Output fields.
Good Luck
Tom Horness
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Wednesday, June 10, 2009 10:40 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Conversion of Drawing file to Shape file
It's not possible to convert it directly. The DWG file can be imported into MapGuide, but that will create SDF files. From there you need to use FDO to create SHP files.
Regards,
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of sathishpsk9
Sent: Tuesday, June 09, 2009 8:07 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Conversion of Drawing file to Shape file
Hi all,
I want to conert drawing file (autocad) to shapefile(ESRI) . Such is
possible with mapguide open source (any version)... any guidlines or urls or
code or dlls are appreciated.
Thanks & Regards,
Satish
View this message in context: http://n2.nabble.com/Conversion-of-Drawing-file-to-Shape-file-tp3049111p3053309.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
