[mapguide-users] 2.1 installation problem
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Wed Jun 10 15:55:50 EDT 2009
Ok - totally fresh install on Windows 2000 server...the one thing I did
do was install 2.0 using IIS and then removing it and installing 2.1 on
Apache. This was to replicate my existing conditions. I get an error
saying that mgserver.exe is unable to locate LIBPQ.dll. I did a search
on the HD and couldn't find it anywhere. This is coming up when I try to
edit a data source that was created and working in 2.0. From what I've
seen so far, it seems to run faster - but until I get a 100% working
install, I'm stuck with 2.0...any help?
Andrew
On 6/2/2009 11:01 AM, Andrew DeMerchant wrote:
> Removing that line in php.ini did nothing for me - same error.....the
> dr.watson log in my event log lists the following (from when httpd
> crashes):
> "The application, , generated an application error The error occurred
> on 06/02/2009 @ 10:38:27.130 The exception generated was c0000005 at
> address 77FCD989 (RtlZeroHeap) "
> I don't know apache, so interactive mode isn't something that I know
> how to do (though I'll gladly try it with instructions). Also, this
> w2k installation is totally up to date with WindowsUpdate.
> Andrew
> On 6/2/2009 10:07 AM, Jackie Ng wrote:
>> Ok I've just done a clean install on a Windows 2000 VM with a trunk build
>> installer (roughly the same as the 2.1 beta) using Apache/PHP and I have a
>> functioning server and web extensions.
>> I also got the same problems with php_MapGuideApiEnvConfig.dll in my error
>> logs.
>> So there must be some other factor at play here.
>> Have you tried running both the MapGuide Server and/or Apache interactively?
>> Please note that I also installed the Windows 2000 Update Rollup package as
>> well. I don't know if this makes a difference.
>> - Jackie
>> Jackie Ng wrote:
>>> Not quite, from your observations it seems the main offender is the
>>> Looking at the source-code, you'll see the GetModuleHandleEx() API I
>>> mentioned being used.
>>> http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.cpp
>>> Now the purpose of the php_MapGuideApiEnvConfig.dll is to resolve multiple
>>> different versions of php installed on the same system.
>>> If the only version of PHP you're using is the one that comes with
>>> MapGuide, then you can remove the reference to
>>> php_MapGuideApiEnvConfig.dll in the php.ini and see if MapGuide is
>>> operational.
>>> If so, then we just need to see if a Windows 2000 equivalent API exists
>>> (GetModuleHandle???) that does the same thing.
>>> - Jackie
>>>> So suddenly with MapGuide 2.1, we've lost Win2k support?? Well that
>>>> seriously sucks, if it's true. That means I'm stuck with 2.0 and on a
>>>> dead end street for the unforeseeable future. Is that correct?
>>>> Andrew
>>>> James Card wrote:
>>>>> Aha! That explains why I was getting the same symptoms last week.
>>>>> Perhaps we could persuade someone to add a note to the downloads page
>>>>> at<http://mapguide.osgeo.org/download/releases/2.1.0>.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
