[mapguide-users] 2.1 installation problem
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Wed Jun 10 15:57:32 EDT 2009
Oh - and OCI.dll is also missing, apparently...
Andrew
On 6/10/2009 4:55 PM, Andrew DeMerchant wrote:
> Ok - totally fresh install on Windows 2000 server...the one thing I
> did do was install 2.0 using IIS and then removing it and installing
> 2.1 on Apache. This was to replicate my existing conditions. I get an
> error saying that mgserver.exe is unable to locate LIBPQ.dll. I did a
> search on the HD and couldn't find it anywhere. This is coming up when
> I try to edit a data source that was created and working in 2.0. From
> what I've seen so far, it seems to run faster - but until I get a 100%
> working install, I'm stuck with 2.0...any help?
> Andrew
> On 6/2/2009 11:01 AM, Andrew DeMerchant wrote:
>> Removing that line in php.ini did nothing for me - same error.....the
>> dr.watson log in my event log lists the following (from when httpd
>> crashes):
>> "The application, , generated an application error The error occurred
>> on 06/02/2009 @ 10:38:27.130 The exception generated was c0000005 at
>> address 77FCD989 (RtlZeroHeap) "
>> I don't know apache, so interactive mode isn't something that I know
>> how to do (though I'll gladly try it with instructions). Also, this
>> w2k installation is totally up to date with WindowsUpdate.
>> Andrew
>> On 6/2/2009 10:07 AM, Jackie Ng wrote:
>>> Ok I've just done a clean install on a Windows 2000 VM with a trunk build
>>> installer (roughly the same as the 2.1 beta) using Apache/PHP and I have a
>>> functioning server and web extensions.
>>> I also got the same problems with php_MapGuideApiEnvConfig.dll in my error
>>> logs.
>>> So there must be some other factor at play here.
>>> Have you tried running both the MapGuide Server and/or Apache interactively?
>>> Please note that I also installed the Windows 2000 Update Rollup package as
>>> well. I don't know if this makes a difference.
>>> - Jackie
>>> Jackie Ng wrote:
>>>> Not quite, from your observations it seems the main offender is the
>>>> Looking at the source-code, you'll see the GetModuleHandleEx() API I
>>>> mentioned being used.
>>>> http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.cpp
>>>> Now the purpose of the php_MapGuideApiEnvConfig.dll is to resolve multiple
>>>> different versions of php installed on the same system.
>>>> If the only version of PHP you're using is the one that comes with
>>>> MapGuide, then you can remove the reference to
>>>> php_MapGuideApiEnvConfig.dll in the php.ini and see if MapGuide is
>>>> operational.
>>>> If so, then we just need to see if a Windows 2000 equivalent API exists
>>>> (GetModuleHandle???) that does the same thing.
>>>> - Jackie
>>>>> So suddenly with MapGuide 2.1, we've lost Win2k support?? Well that
>>>>> seriously sucks, if it's true. That means I'm stuck with 2.0 and on a
>>>>> dead end street for the unforeseeable future. Is that correct?
>>>>> Andrew
>>>>> James Card wrote:
>>>>>> Aha! That explains why I was getting the same symptoms last week.
>>>>>> Perhaps we could persuade someone to add a note to the downloads page
>>>>>> at<http://mapguide.osgeo.org/download/releases/2.1.0>.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> *Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
