[mapguide-users] 2.1 installation problem
Zac Spitzer
zac.spitzer at gmail.com
Wed Jun 10 22:35:11 EDT 2009
try commenting out the fdo providers your not using from providers.xml
On Thu, Jun 11, 2009 at 5:57 AM, Andrew
DeMerchant<andrew.demerchant at gemtec.ca> wrote:
> Oh - and OCI.dll is also missing, apparently...
> Andrew
> On 6/10/2009 4:55 PM, Andrew DeMerchant wrote:
> Ok - totally fresh install on Windows 2000 server...the one thing I did do
> was install 2.0 using IIS and then removing it and installing 2.1 on Apache.
> This was to replicate my existing conditions. I get an error saying that
> mgserver.exe is unable to locate LIBPQ.dll. I did a search on the HD and
> couldn't find it anywhere. This is coming up when I try to edit a data
> source that was created and working in 2.0. From what I've seen so far, it
> seems to run faster - but until I get a 100% working install, I'm stuck with
> 2.0...any help?
> Andrew
> On 6/2/2009 11:01 AM, Andrew DeMerchant wrote:
> Removing that line in php.ini did nothing for me - same error.....the
> dr.watson log in my event log lists the following (from when httpd crashes):
> "The application, , generated an application error The error occurred on
> 06/02/2009 @ 10:38:27.130 The exception generated was c0000005 at address
> 77FCD989 (RtlZeroHeap) "
> I don't know apache, so interactive mode isn't something that I know how to
> do (though I'll gladly try it with instructions). Also, this w2k
> installation is totally up to date with WindowsUpdate.
> Andrew
> On 6/2/2009 10:07 AM, Jackie Ng wrote:
> Ok I've just done a clean install on a Windows 2000 VM with a trunk build
> installer (roughly the same as the 2.1 beta) using Apache/PHP and I have a
> functioning server and web extensions.
> I also got the same problems with php_MapGuideApiEnvConfig.dll in my error
> logs.
> So there must be some other factor at play here.
> Have you tried running both the MapGuide Server and/or Apache interactively?
> Please note that I also installed the Windows 2000 Update Rollup package as
> well. I don't know if this makes a difference.
> - Jackie
> Jackie Ng wrote:
> Not quite, from your observations it seems the main offender is the
> Looking at the source-code, you'll see the GetModuleHandleEx() API I
> mentioned being used.
> http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.cpp
> Now the purpose of the php_MapGuideApiEnvConfig.dll is to resolve multiple
> different versions of php installed on the same system.
> If the only version of PHP you're using is the one that comes with
> MapGuide, then you can remove the reference to
> php_MapGuideApiEnvConfig.dll in the php.ini and see if MapGuide is
> operational.
> If so, then we just need to see if a Windows 2000 equivalent API exists
> (GetModuleHandle???) that does the same thing.
> - Jackie
> So suddenly with MapGuide 2.1, we've lost Win2k support?? Well that
> seriously sucks, if it's true. That means I'm stuck with 2.0 and on a
> dead end street for the unforeseeable future. Is that correct?
> Andrew
> James Card wrote:
> Aha! That explains why I was getting the same symptoms last week.
> Perhaps we could persuade someone to add a note to the downloads page
> at <http://mapguide.osgeo.org/download/releases/2.1.0>.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> Andrew DeMerchant
> Computer Technologist
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> GEMTEC Limited
> 191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> ________________________________
> Andrew DeMerchant
> fax 506-453-9470
> GEMTEC Limited
> 191 Doak Road
> E3C 2E6
> Andrew DeMerchant
> fax 506-453-9470
> GEMTEC Limited
> 191 Doak Road
> E3C 2E6
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
