[mapguide-users] King.Oracle important update
Olyster
mcnolii at hotmail.com
Thu Jun 11 09:51:50 EDT 2009
Marius,
did you try to restart MGService after making changes in providers.xml ?
I had the same problem ; setup King Oracle, modify providers.xml, blank in
MGStudio.
I restarted the service and everything was fine.
marius.360 wrote:
> Hi Harris,
> I have tried to get my MGOS 2.0.2 working with the latest King.Oracle
> provider, but I am having difficulties with that. It works fine with 2.1.
> I just replace the old DLL's with the new ones and then edit the
> providers.xml file to reflect the new version on the 2.0.2 setup, but it
> doesn't work, if I open an existing data connection in studio it is blank.
> Is there anything else I must do to get it working on 2.0.2? I must be
> doing something silly...
> Please pardon my ignorance, but I am a bit of a novice in this regard!
> Marius
> Haris Kurtagic wrote:
>> Yes it can. We use it with MG 2.0.2.
>> When I build new version of provider I build for older versions of FDO
>> too. So you can use it as far back as MapGuide 1.2 (FDO 3.2.2).
>> Haris
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of marius.360
>> Sent: Tuesday, June 09, 2009 2:36 PM
>> To: mapguide-users at lists.osgeo.org
>> Subject: Re: [mapguide-users] King.Oracle important update
>> Hi Haris
>> This is very good news! Quick question though, can this new version be
>> used
>> with version 2.0.2 of mapguide?
>> Thanks a lot,
>> Marius
>>> Hi,
>>> I have released new version of King.Oracle provider. It solves
>> stability
>>> issue with MapGuide and King.Oracle.
>>> http://www.sl-king.com/fdooracle/
>>> Haris
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://n2.nabble.com/King.Oracle-important-update-tp3048272p3049174.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/King.Oracle-important-update-tp3048272p3062092.html
