[mapguide-users] King.Oracle important update
marius.360 marius at osssa.co.za
Thu Jun 11 09:58:25 EDT 2009
Yes I restarted the service, as well as the server when that didn't work.
Perhaps I made a mistake in entering some of the text in the providers.xml,
but I am not sure as the same thing works for 2.1. Can you perhaps send me
your entry for the King.Oracle provider in your providers.xml? Then I can
just paste and see if it solves my problem.
Marius
Olyster wrote:
> Marius,
> did you try to restart MGService after making changes in providers.xml ?
> I had the same problem ; setup King Oracle, modify providers.xml, blank in
> MGStudio.
> I restarted the service and everything was fine.
> marius.360 wrote:
>> Hi Harris,
>> I have tried to get my MGOS 2.0.2 working with the latest King.Oracle
>> provider, but I am having difficulties with that. It works fine with 2.1.
>> I just replace the old DLL's with the new ones and then edit the
>> providers.xml file to reflect the new version on the 2.0.2 setup, but it
>> doesn't work, if I open an existing data connection in studio it is
>> blank. Is there anything else I must do to get it working on 2.0.2? I
>> must be doing something silly...
>> Please pardon my ignorance, but I am a bit of a novice in this regard!
>> Marius
>> Haris Kurtagic wrote:
>>> Yes it can. We use it with MG 2.0.2.
>>> When I build new version of provider I build for older versions of FDO
>>> too. So you can use it as far back as MapGuide 1.2 (FDO 3.2.2).
>>> Haris
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of marius.360
>>> Sent: Tuesday, June 09, 2009 2:36 PM
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: Re: [mapguide-users] King.Oracle important update
>>> Hi Haris
>>> This is very good news! Quick question though, can this new version be
>>> used
>>> with version 2.0.2 of mapguide?
>>> Thanks a lot,
>>> Marius
>>>> Hi,
>>>> I have released new version of King.Oracle provider. It solves
>>> stability
>>>> issue with MapGuide and King.Oracle.
>>>> http://www.sl-king.com/fdooracle/
>>>> Haris
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> View this message in context:
>>> http://n2.nabble.com/King.Oracle-important-update-tp3048272p3049174.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/King.Oracle-important-update-tp3048272p3062124.html
