[mapguide-users] King.Oracle important update
Olyster mcnolii at hotmail.com
Thu Jun 11 10:10:22 EDT 2009
<FeatureProvider>
  <Name>King.Oracle.0.1.1</Name>
  <DisplayName>King Provider for Oracle</DisplayName>
  <Description>Read/write access to spatial and attribute data in an Oracle
Spatial.</Description>
  <IsManaged>False</IsManaged>
  <Version>0.1.1.0</Version>
  <FeatureDataObjectsVersion>3.3.0.0</FeatureDataObjectsVersion>
  <LibraryPath>KingOracleProvider.dll</LibraryPath>
</FeatureProvider>
use the same FDOObjVersion as all the other in providers.xml ... in this
case 3.3.0.0
marius.360 wrote:
> Yes I restarted the service, as well as the server when that didn't work.
> Perhaps I made a mistake in entering some of the text in the
> providers.xml, but I am not sure as the same thing works for 2.1. Can you
> perhaps send me your entry for the King.Oracle provider in your
> providers.xml? Then I can just paste and see if it solves my problem.
> Marius
> Olyster wrote:
>> Marius,
>> did you try to restart MGService after making changes in providers.xml ?
>> I had the same problem ; setup King Oracle, modify providers.xml, blank
>> in MGStudio.
>> I restarted the service and everything was fine.
>> marius.360 wrote:
>>> Hi Harris,
>>> I have tried to get my MGOS 2.0.2 working with the latest King.Oracle
>>> provider, but I am having difficulties with that. It works fine with
>>> 2.1. I just replace the old DLL's with the new ones and then edit the
>>> providers.xml file to reflect the new version on the 2.0.2 setup, but it
>>> doesn't work, if I open an existing data connection in studio it is
>>> blank. Is there anything else I must do to get it working on 2.0.2? I
>>> must be doing something silly...
>>> Please pardon my ignorance, but I am a bit of a novice in this regard!
>>> Marius
>>> Haris Kurtagic wrote:
>>>> Yes it can. We use it with MG 2.0.2.
>>>> When I build new version of provider I build for older versions of FDO
>>>> too. So you can use it as far back as MapGuide 1.2 (FDO 3.2.2).
>>>> Haris
>>>> -----Original Message-----
>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of marius.360
>>>> Sent: Tuesday, June 09, 2009 2:36 PM
>>>> To: mapguide-users at lists.osgeo.org
>>>> Subject: Re: [mapguide-users] King.Oracle important update
>>>> Hi Haris
>>>> This is very good news! Quick question though, can this new version be
>>>> used
>>>> with version 2.0.2 of mapguide?
>>>> Thanks a lot,
>>>> Marius
>>>>> Hi,
>>>>> I have released new version of King.Oracle provider. It solves
>>>> stability
>>>>> issue with MapGuide and King.Oracle.
>>>>> http://www.sl-king.com/fdooracle/
>>>>> Haris
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> View this message in context:
>>>> http://n2.nabble.com/King.Oracle-important-update-tp3048272p3049174.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/King.Oracle-important-update-tp3048272p3062199.html
