[mapguide-users] Getting User domain and username active directory from task pane
Olyster mcnolii at hotmail.com
Fri Jun 12 09:54:51 EDT 2009
Kenneth,
thanks for your answer.
I want to retrieve user's domain info for another purpose ... not to
authenticate the user in MapGuide.
Since I get nothing when using my code in a page residing in the taskPane
but I can get it in my startpage, I want to pass it the the MapGuide using
GET method ... like WebLayout, Locale, etc ...
I have a startpage where I call the Mapguide page (ex:<iframe
src="/mapguide/mapviewerajax/?SESSION=???&WEBLAYOUT=???" />) and I pass the
domain information with an extra parameter &DomInfo=...
How can I retrieve this values from an aspx page residing in the TaskPane ?
I tried with request.querystring("DomInfo") but I get nothing ...
Thanks ... I'm almost there !
Kenneth Skovhede, GEOGRAF A/S wrote:
> There are a number of issues when doing this.
> First, the .aspx files in MapGuide run in their own application pool,
> and are not normally subjected to integrated authentication.
> I'm not sure if it is possible to use integrated authentication
> with MapGuide as it has some custom authentication.
> Even if it is possible, you should not modify those files,
> because you will get a hard time when upgrading MapGuide later on.
> Instead, you can set a startup page that gets loaded in as the right side
> pane. That page can be in another app pool, and have integrated
> authentication,
> and you can put your own code in it.
> You may also want to serve the map through a starting aspx page,
> that outputs something like this:
> <iframe src="/mapguide/mapviewerajax/?SESSION=???&WEBLAYOUT=???" />
> You can also autologin the user in such a page.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Olyster skrev:
>> Hi,
>> I'm new to MapGuide.
>> I want to retrieve active directory domain and user name from TaskPane. I
>> used MapGuide Studio to create a web layout and I developed a webpage
>> (RightPane.aspx) with Visual Web Developer to be displayed in the
>> taskPane.
>> I have a header frame (containing HeaderFrame.aspx which is showing a
>> banner) and the MapGuide frame below.
>> >From the Header Frame, I can get user's active directory info using :
>> Dim User As System.Security.Principal.IPrincipal
>> User = System.Web.HttpContext.Current.User
>> TxtUser.Text = User.Identity.Name
>> Which returns the domain name and user name of the currently connected
>> user.
>> But If I try to get the same info with the same code in the page.load of
>> RightPane.aspx, I get nothing and I can't debug the page. I have to set
>> it
>> as start page to debug it.
>> I tried to go up to the HeaderFrame from RightPane.aspx using javascript
>> but
>> I get Access denied at a certain point (different domain I guess)
>> So I'd like to know how I can debug a custom .aspx page which resides in
>> the
>> TaskPane and/or Get active directory info from a page which resides in
>> the
>> taskPane.
>> I hope this is clear enough.
>> Thanks for your help.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Getting-User-domain-and-username-active-directory-from-task-pane-tp3056279p3067759.html
