[mapguide-users] Getting User domain and username active directory
from task pane
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Sun Jun 14 13:33:51 EDT 2009
I don't know if it is possible to read that information in the
task pane, but I'm guessing you can't.
If the DomInfo parameter is related to security, its
not a good idea to pass it like this, because
an evil user can change it very easily.
The integrated authentication can be set on a file
or directory level. If you run the .aspx from somewhere
outside the MapGuide folder, you should
be able to get the correct credentials.
Eg, your aspx would be in:
http://server/myapplication/start_page_for_task_pane.aspx
And in the weblayout, you set the start page to be:
You then remove the "Allow anonymous access" in
IIS properties for the folder "myapplication",
and check the "Integrated Autentication" option.
It does not matter if the page is inside the
frames for the MapGuide viewer, or you call it directly,
the authentication works the same way.
Regards, Kenneth Skovhede, GEOGRAF A/S
Olyster skrev:
> Kenneth,
> thanks for your answer.
> I want to retrieve user's domain info for another purpose ... not to
> authenticate the user in MapGuide.
> Since I get nothing when using my code in a page residing in the taskPane
> but I can get it in my startpage, I want to pass it the the MapGuide using
> GET method ... like WebLayout, Locale, etc ...
> I have a startpage where I call the Mapguide page (ex:<iframe
> src="/mapguide/mapviewerajax/?SESSION=???&WEBLAYOUT=???" />) and I pass the
> domain information with an extra parameter &DomInfo=...
> How can I retrieve this values from an aspx page residing in the TaskPane ?
> I tried with request.querystring("DomInfo") but I get nothing ...
> Thanks ... I'm almost there !
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> There are a number of issues when doing this.
>> First, the .aspx files in MapGuide run in their own application pool,
>> and are not normally subjected to integrated authentication.
>> I'm not sure if it is possible to use integrated authentication
>> with MapGuide as it has some custom authentication.
>> Even if it is possible, you should not modify those files,
>> because you will get a hard time when upgrading MapGuide later on.
>> Instead, you can set a startup page that gets loaded in as the right side
>> pane. That page can be in another app pool, and have integrated
>> authentication,
>> and you can put your own code in it.
>> You may also want to serve the map through a starting aspx page,
>> that outputs something like this:
>> <iframe src="/mapguide/mapviewerajax/?SESSION=???&WEBLAYOUT=???" />
>> You can also autologin the user in such a page.
>> Olyster skrev:
>>> Hi,
>>> I'm new to MapGuide.
>>> I want to retrieve active directory domain and user name from TaskPane. I
>>> used MapGuide Studio to create a web layout and I developed a webpage
>>> (RightPane.aspx) with Visual Web Developer to be displayed in the
>>> taskPane.
>>> I have a header frame (containing HeaderFrame.aspx which is showing a
>>> banner) and the MapGuide frame below.
>>> >From the Header Frame, I can get user's active directory info using :
>>> Dim User As System.Security.Principal.IPrincipal
>>> User = System.Web.HttpContext.Current.User
>>> TxtUser.Text = User.Identity.Name
>>> Which returns the domain name and user name of the currently connected
>>> user.
>>> But If I try to get the same info with the same code in the page.load of
>>> RightPane.aspx, I get nothing and I can't debug the page. I have to set
>>> it
>>> as start page to debug it.
>>> I tried to go up to the HeaderFrame from RightPane.aspx using javascript
>>> but
>>> I get Access denied at a certain point (different domain I guess)
>>> So I'd like to know how I can debug a custom .aspx page which resides in
>>> the
>>> TaskPane and/or Get active directory info from a page which resides in
>>> the
>>> taskPane.
>>> I hope this is clear enough.
>>> Thanks for your help.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090614/680539d0/attachment.html
