[mapguide-users] more 2.1 problems (GDAL this time)
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Sat Jun 13 08:23:18 EDT 2009
The config.xml is attached as a resource file.
In Maestro, click the "generic editor" tab, and then click the "Show
all" button.
Note that the file may be called something else than "config.xml"
(usually just config).
Regards, Kenneth Skovhede, GEOGRAF A/S
Zac Spitzer skrev:
> Andrew,
> please remember your testing a BETA, expect some pain :)
> are you running mapguide under a user account?
> z
> On Sat, Jun 13, 2009 at 5:18 AM, Andrew
> DeMerchant<andrew.demerchant at gemtec.ca> wrote:
>> How do I get at that config.xml? I don't see it in Maestro...that's likely
>> the problem though. I had tried to keep my alias the same, but thanks to a
>> buggy handling of mapped drives, that didn't work. I then copied things
>> locally and moved the alias....which means that the local path would be
>> different. But I have gone into Maestro and edited the path since then, to
>> use the new alias....would it not overwrite the config.xml with the new,
>> correct path?
>> andrew
>> On 6/12/2009 4:09 PM, Dave Wilson wrote:
>> When you "Upgraded" did you import a package to a new instance or did you
>> upgrade in place?
>> There is a design issue with FDO such that it doesn't know about the MG
>> aliases. The paths to the data are expanded and written into the config.xml.
>> If the path has changed then this will fail. For example if you had local
>> data under e:\data and now it's on d:\data.
>> If the path on the alias has changed this would explain why you can see the
>> data in Maestro, but unless you resave the source the config.xml might be
>> incorrect.
>> Of course if no paths have changed (note I didn't say Alias) then something
>> else is likely wrong.
>> Dave
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew
>> DeMerchant
>> Sent: Friday, June 12, 2009 12:53 PM
>> To: MapGuide Users Mail List
>> Subject: [mapguide-users] more 2.1 problems (GDAL this time)
>> Sorry for the barrage of problems - but this seems to happen every time
>> there's an update....I've said it before, but it would be REALLY nice if the
>> upgrade process could be made without breaking everything.
>> Anyway - my problem right now is with the gdal provider. I had an air photo
>> layer and data source working fine in 2.0....after the upgrade to 2.1, that
>> died. If I edit the existing datasource, and do a preview of it, I don't see
>> any of my photos listed (the datasource points to an alias - which works,
>> because I see the files listed in Maestro). I've tried debugging using
>> CPL_DEBUG=ON, but that's not giving me any errors. I'm totally stumped as to
>> where to go from here. I also get the same problem if I make a brand new
>> datasource...
>> Andrew
>> Andrew DeMerchant
>> Computer Technologist
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> GEMTEC Limited
>> 191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
>> ________________________________
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Andrew DeMerchant
>> fax 506-453-9470
>> GEMTEC Limited
>> 191 Doak Road
>> E3C 2E6
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090613/2e9d4b7a/attachment.html
