[mapguide-users] more 2.1 problems (GDAL this time)
Andrew DeMerchant andrew.demerchant at gemtec.ca
Mon Jun 15 08:14:54 EDT 2009
I thought that that was how you were supposed to do it - but I don't see
any files. When I press "Show all", my list stays blank. I've tried
changing the type (right click) - no change. If I make a brand new data
connection - same thing. No config.xml - nothing listed at all from
"show all".
I know it's still a beta - it's just feeling more like an alpha right
now, that's all. It's just a typical problem with upgrade headaches
every time a new version gets put out - beta or not. I'm running this
all as a default install on apache. It's running as Local System.
Andrew
On 6/13/2009 9:23 AM, Kenneth Skovhede, GEOGRAF A/S wrote:
> The config.xml is attached as a resource file.
> In Maestro, click the "generic editor" tab, and then click the "Show
> all" button.
> Note that the file may be called something else than "config.xml"
> (usually just config).
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Zac Spitzer skrev:
>> Andrew,
>> please remember your testing a BETA, expect some pain :)
>> are you running mapguide under a user account?
>> z
>> On Sat, Jun 13, 2009 at 5:18 AM, Andrew
>> DeMerchant<andrew.demerchant at gemtec.ca>  wrote:
>>> How do I get at that config.xml? I don't see it in Maestro...that's likely
>>> the problem though. I had tried to keep my alias the same, but thanks to a
>>> buggy handling of mapped drives, that didn't work. I then copied things
>>> locally and moved the alias....which means that the local path would be
>>> different. But I have gone into Maestro and edited the path since then, to
>>> use the new alias....would it not overwrite the config.xml with the new,
>>> correct path?
>>> andrew
>>> On 6/12/2009 4:09 PM, Dave Wilson wrote:
>>> When you "Upgraded" did you import a package to a new instance or did you
>>> upgrade in place?
>>> There is a design issue with FDO such that it doesn't know about the MG
>>> aliases. The paths to the data are expanded and written into the config.xml.
>>> If the path has changed then this will fail. For example if you had local
>>> data under e:\data and now it's on d:\data.
>>> If the path on the alias has changed this would explain why you can see the
>>> data in Maestro, but unless you resave the source the config.xml might be
>>> incorrect.
>>> Of course if no paths have changed (note I didn't say Alias) then something
>>> else is likely wrong.
>>> Dave
>>> From:mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew
>>> DeMerchant
>>> Sent: Friday, June 12, 2009 12:53 PM
>>> To: MapGuide Users Mail List
>>> Subject: [mapguide-users] more 2.1 problems (GDAL this time)
>>> Sorry for the barrage of problems - but this seems to happen every time
>>> there's an update....I've said it before, but it would be REALLY nice if the
>>> upgrade process could be made without breaking everything.
>>> Anyway - my problem right now is with the gdal provider. I had an air photo
>>> layer and data source working fine in 2.0....after the upgrade to 2.1, that
>>> died. If I edit the existing datasource, and do a preview of it, I don't see
>>> any of my photos listed (the datasource points to an alias - which works,
>>> because I see the files listed in Maestro). I've tried debugging using
>>> CPL_DEBUG=ON, but that's not giving me any errors. I'm totally stumped as to
>>> where to go from here. I also get the same problem if I make a brand new
>>> datasource...
>>> Andrew
>>> Andrew DeMerchant
>>> Computer Technologist
>>> ph.1-877-2GEMTEC x.163
>>> fax 506-453-9470
>>> GEMTEC Limited
>>> 191 Doak Road
>>> Fredericton, NB, Canada
>>> E3C 2E6
>>> ________________________________
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Andrew DeMerchant
>>> fax 506-453-9470
>>> GEMTEC Limited
>>> 191 Doak Road
>>> E3C 2E6
	*Andrew DeMerchant*
*Computer Technologist*
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
