[mapguide-users] more 2.1 problems (GDAL this time)
Zac Spitzer
zac.spitzer at gmail.com
Mon Jun 15 09:57:16 EDT 2009
well as local system you are restricted to what you can access
On Mon, Jun 15, 2009 at 10:14 PM, Andrew
DeMerchant<andrew.demerchant at gemtec.ca> wrote:
> I thought that that was how you were supposed to do it - but I don't see any
> files. When I press "Show all", my list stays blank. I've tried changing the
> type (right click) - no change. If I make a brand new data connection - same
> thing. No config.xml - nothing listed at all from "show all".
> I know it's still a beta - it's just feeling more like an alpha right now,
> that's all. It's just a typical problem with upgrade headaches every time a
> new version gets put out - beta or not. I'm running this all as a default
> install on apache. It's running as Local System.
> Andrew
> On 6/13/2009 9:23 AM, Kenneth Skovhede, GEOGRAF A/S wrote:
> The config.xml is attached as a resource file.
> In Maestro, click the "generic editor" tab, and then click the "Show all"
> button.
> Note that the file may be called something else than "config.xml" (usually
> just config).
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Zac Spitzer skrev:
> Andrew,
> please remember your testing a BETA, expect some pain :)
> are you running mapguide under a user account?
> z
> On Sat, Jun 13, 2009 at 5:18 AM, Andrew
> How do I get at that config.xml? I don't see it in Maestro...that's likely
> the problem though. I had tried to keep my alias the same, but thanks to a
> buggy handling of mapped drives, that didn't work. I then copied things
> locally and moved the alias....which means that the local path would be
> different. But I have gone into Maestro and edited the path since then, to
> use the new alias....would it not overwrite the config.xml with the new,
> correct path?
> andrew
> On 6/12/2009 4:09 PM, Dave Wilson wrote:
> When you "Upgraded" did you import a package to a new instance or did you
> upgrade in place?
> There is a design issue with FDO such that it doesn't know about the MG
> aliases. The paths to the data are expanded and written into the config.xml.
> If the path has changed then this will fail. For example if you had local
> data under e:\data and now it's on d:\data.
> If the path on the alias has changed this would explain why you can see the
> data in Maestro, but unless you resave the source the config.xml might be
> incorrect.
> Of course if no paths have changed (note I didn't say Alias) then something
> else is likely wrong.
> Dave
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew
> DeMerchant
> Sent: Friday, June 12, 2009 12:53 PM
> To: MapGuide Users Mail List
> Subject: [mapguide-users] more 2.1 problems (GDAL this time)
> Sorry for the barrage of problems - but this seems to happen every time
> there's an update....I've said it before, but it would be REALLY nice if the
> upgrade process could be made without breaking everything.
> Anyway - my problem right now is with the gdal provider. I had an air photo
> layer and data source working fine in 2.0....after the upgrade to 2.1, that
> died. If I edit the existing datasource, and do a preview of it, I don't see
> any of my photos listed (the datasource points to an alias - which works,
> because I see the files listed in Maestro). I've tried debugging using
> CPL_DEBUG=ON, but that's not giving me any errors. I'm totally stumped as to
> where to go from here. I also get the same problem if I make a brand new
> datasource...
> Andrew
> Andrew DeMerchant
> Computer Technologist
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> GEMTEC Limited
> 191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> ________________________________
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> Andrew DeMerchant
> fax 506-453-9470
> GEMTEC Limited
> 191 Doak Road
> E3C 2E6
> Andrew DeMerchant
> fax 506-453-9470
> GEMTEC Limited
> 191 Doak Road
> E3C 2E6
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
