[mapguide-users] more 2.1 problems (GDAL this time)
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Mon Jun 15 10:02:20 EDT 2009
My production server's running the same way with no problems....my data
is all local and accessible. I'm seeing no access errors.
Andrew
On 6/15/2009 10:57 AM, Zac Spitzer wrote:
> well as local system you are restricted to what you can access
> On Mon, Jun 15, 2009 at 10:14 PM, Andrew
> DeMerchant<andrew.demerchant at gemtec.ca> wrote:
>> I thought that that was how you were supposed to do it - but I don't see any
>> files. When I press "Show all", my list stays blank. I've tried changing the
>> type (right click) - no change. If I make a brand new data connection - same
>> thing. No config.xml - nothing listed at all from "show all".
>> I know it's still a beta - it's just feeling more like an alpha right now,
>> that's all. It's just a typical problem with upgrade headaches every time a
>> new version gets put out - beta or not. I'm running this all as a default
>> install on apache. It's running as Local System.
>> Andrew
>> On 6/13/2009 9:23 AM, Kenneth Skovhede, GEOGRAF A/S wrote:
>> The config.xml is attached as a resource file.
>> In Maestro, click the "generic editor" tab, and then click the "Show all"
>> button.
>> Note that the file may be called something else than "config.xml" (usually
>> just config).
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> Zac Spitzer skrev:
>> Andrew,
>> please remember your testing a BETA, expect some pain :)
>> are you running mapguide under a user account?
>> z
>> On Sat, Jun 13, 2009 at 5:18 AM, Andrew
>> How do I get at that config.xml? I don't see it in Maestro...that's likely
>> the problem though. I had tried to keep my alias the same, but thanks to a
>> buggy handling of mapped drives, that didn't work. I then copied things
>> locally and moved the alias....which means that the local path would be
>> different. But I have gone into Maestro and edited the path since then, to
>> use the new alias....would it not overwrite the config.xml with the new,
>> correct path?
>> andrew
>> On 6/12/2009 4:09 PM, Dave Wilson wrote:
>> When you "Upgraded" did you import a package to a new instance or did you
>> upgrade in place?
>> There is a design issue with FDO such that it doesn't know about the MG
>> aliases. The paths to the data are expanded and written into the config.xml.
>> If the path has changed then this will fail. For example if you had local
>> data under e:\data and now it's on d:\data.
>> If the path on the alias has changed this would explain why you can see the
>> data in Maestro, but unless you resave the source the config.xml might be
>> incorrect.
>> Of course if no paths have changed (note I didn't say Alias) then something
>> else is likely wrong.
>> Dave
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew
>> DeMerchant
>> Sent: Friday, June 12, 2009 12:53 PM
>> To: MapGuide Users Mail List
>> Subject: [mapguide-users] more 2.1 problems (GDAL this time)
>> Sorry for the barrage of problems - but this seems to happen every time
>> there's an update....I've said it before, but it would be REALLY nice if the
>> upgrade process could be made without breaking everything.
>> Anyway - my problem right now is with the gdal provider. I had an air photo
>> layer and data source working fine in 2.0....after the upgrade to 2.1, that
>> died. If I edit the existing datasource, and do a preview of it, I don't see
>> any of my photos listed (the datasource points to an alias - which works,
>> because I see the files listed in Maestro). I've tried debugging using
>> CPL_DEBUG=ON, but that's not giving me any errors. I'm totally stumped as to
>> where to go from here. I also get the same problem if I make a brand new
>> datasource...
>> Andrew
>> Andrew DeMerchant
>> Computer Technologist
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> GEMTEC Limited
>> 191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
>> ________________________________
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Andrew DeMerchant
>> fax 506-453-9470
>> GEMTEC Limited
>> 191 Doak Road
>> E3C 2E6
>> Andrew DeMerchant
>> fax 506-453-9470
>> GEMTEC Limited
>> 191 Doak Road
>> E3C 2E6
*Andrew DeMerchant*
*Computer Technologist*
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
