[mapguide-users] FDO Toolbox - MapView
Jackie Ng
jumpinjackie at gmail.com
Sun Jun 14 19:55:03 EDT 2009
1. Was your SDF produced by AutoCAD Map 2010? Map 2010 makes SDFs containing
3-dimensional geometries, that the map preview can't handle.
2. There should be an "Add" button below the computed properties. This will
bring up the expression editor where you can enter the required expression.
- Jackie
Nimrod Cnaan wrote:
> Hi Jackie
> Grate tool, we are using it on a daily basis.
> I have couple of problems:
> 1. can't see sdf preview in the "Map View" tab
> 2. how do I add a new functionality to the computed properties tab -
> String function Expression to create a reverse string column
>> Date: Fri, 17 Apr 2009 10:33:11 -0700
>> From: jumpinjackie at gmail.com
>> To: mapguide-users at lists.osgeo.org
>> Subject: Re: [mapguide-users] FDO toolbox help
>> I've made a new release of FDO Toolbox that not only fixes the Generic
>> control for RDBMS providers, but also provides an express SQL Server 2008
>> spatial connection option.
>> Cheers,
>> - Jackie
>> This is a defect with the Generic control that makes it unusable with
>> RDBMS-based providers or any providers that have connection properties
>> which are only available when connected.
>> This will be fixed for the next release. The workaround in the meantime,
>> would be to use the express connection method for [your RDBMS].
>> Unfortunately, SQL Server 2008 does not have an express connection
>> method. It will for the next release.
>> - Jackie
>> Hi Jackie, I am trying to use this tool in order to convert shp to
>> sql2008.
>> I wanted to connect to sql2008 database but with no success.
>> I have attached a screenshot with the error that I got it.
>> I am using the 0.7.1.2118 version.
>> could you help me with it?
>> thanks in advance,
>> View this message in context:
>> http://n2.nabble.com/FDO-toolbox-help-tp2572209p2651987.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> _________________________________________________________________
> Show them the way! Add maps and directions to your party invites.
> http://www.microsoft.com/windows/windowslive/products/events.aspx
View this message in context: http://n2.nabble.com/FDO-toolbox-help-tp2572209p3077622.html
