[mapguide-users] FDO Toolbox - MapView
Nimrod Cnaan nimcnaan at hotmail.com
Sun Jun 14 04:11:24 EDT 2009
Hi Jackie
Grate tool, we are using it on a daily basis.
I have couple of problems:
1. can't see sdf preview in the "Map View" tab
2. how do I add a new functionality to the computed properties tab - String function Expression to create a reverse string column
> Date: Fri, 17 Apr 2009 10:33:11 -0700
> From: jumpinjackie at gmail.com
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] FDO toolbox help
> I've made a new release of FDO Toolbox that not only fixes the Generic control for RDBMS providers, but also provides an express SQL Server 2008 spatial connection option.
> Cheers,
> - Jackie
> This is a defect with the Generic control that makes it unusable with RDBMS-based providers or any providers that have connection properties which are only available when connected.
> This will be fixed for the next release. The workaround in the meantime, would be to use the express connection method for [your RDBMS]. Unfortunately, SQL Server 2008 does not have an express connection method. It will for the next release.
> - Jackie
> Hi Jackie, I am trying to use this tool in order to convert shp to sql2008.
> I wanted to connect to sql2008 database but with no success.
> I have attached a screenshot with the error that I got it.
> I am using the 0.7.1.2118 version.
> could you help me with it?
> thanks in advance,
> View this message in context: http://n2.nabble.com/FDO-toolbox-help-tp2572209p2651987.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
_________________________________________________________________
Show them the way! Add maps and directions to your party invites.
http://www.microsoft.com/windows/windowslive/products/events.aspx
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090614/ccaafe36/attachment.html
