[mapguide-users] more 2.1 problems (GDAL this time)
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Thu Jun 18 08:35:51 EDT 2009
The forward slash is what Maestro puts in - and works fine (at least, in
2.0). I've seen nothing at all when I try to debug - no errors....I
suspect this is because when I preview the data source, I see nothing in
it.
Andrew
On 6/18/2009 3:52 AM, Kenneth Skovhede, GEOGRAF A/S wrote:
> You have a forward slash, which should be a backwards one, not sure if
> it fixes anything though.
> Have you tried the approach described for debugging rasters?
> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
> The very least, it should display the path to the files it is trying
> to open.
> Hopefully it will also show if it recognizes the files or not.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Andrew DeMerchant skrev:
>> It's a folder....but I can't make a single file work either. I've
>> also just tried it on a new server install (Windows Server 2008 - vs
>> 2000) - same thing. I've tried with and without the backslash - no
>> change. Here's the xml:
>> <?xml version="1.0" encoding="utf-8"?>
>> <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>> xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>> <Provider>OSGeo.Gdal</Provider>
>> <Parameter>
>> <Name>DefaultRasterFileLocation</Name>
>> <Value>%MG_DATA_PATH_ALIAS[435989]%air_photos/</Value>
>> </Parameter>
>> <SupplementalSpatialContextInfo>
>> <Name>unnamed</Name>
>> <CoordinateSystem>PROJCS["CANST-NB83-CSRS",GEOGCS["LL-CSRS",DATUM["CSRS",SPHEROID["GRS1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Oblique_Stereographic"],PARAMETER["false_easting",2500000.000],PARAMETER["false_northing",7500000.000],PARAMETER["latitude_of_origin",46.50000000000000],PARAMETER["central_meridian",-66.50000000000000],PARAMETER["scale_factor",0.999912000000],UNIT["Meter",1.00000000000000]]</CoordinateSystem>
>> </SupplementalSpatialContextInfo>
>> </FeatureSource>
>> Andrew
>> On 6/16/2009 3:37 AM, Kenneth Skovhede, GEOGRAF A/S wrote:
>>> Are you using a single file or a folder?
>>> I remember having trouble with OGR, because the alias substitution
>>> ends with a backslash,
>>> and the OGR provider chokes on it.
>>> Do you have the same setup on the test and production server?
>>> Could you send the xml for the featuresource?
>>>> The alias is now pointing to the C drive (local), since mapped
>>>> drives was not working. The alias is fine, for sure - I see the
>>>> files inside of the alias from within Maestro, as well as
>>>> EnumerateUnmanagedData.
>>>> Andrew
>>>> On 6/15/2009 3:27 PM, Jason Birch wrote:
>>>>> Andrew,
>>>>> What path is the alias pointing to? Have you restarted the server
>>>>> since changing to UNCs?
>>>>> Jason
>>>>> *From:* Andrew DeMerchant
>>>>> *Sent:* Monday, June 15, 2009 11:01 AM
>>>>> *To:* MapGuide Users Mail List
>>>>> *Subject:* Re: [mapguide-users] more 2.1 problems (GDAL this time)
>>>>> I just checked with 2.0.2 and I get the same results. Seems like
>>>>> it doesn't need to make one in order to work. Any other thoughts?
>>>>> I'm still unable to get this working...
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> *Andrew DeMerchant*
>>>> *Computer Technologist*
>>>> ph.1-877-2GEMTEC x.163
>>>> fax 506-453-9470
>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>> /191 Doak Road
>>>> Fredericton, NB, Canada
>>>> E3C 2E6
>> *Andrew DeMerchant*
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
This e-mail message (including attachments, if any) is confidential and may be privileged. Any unauthorized distribution or disclosure is prohibited. Disclosure to anyone other than the intended recipient does not constitute waiver of privilege. If you have received this e-mail in error, please notify us and delete it and any attachments from your computer system and records.
Ce courriel (y compris les pièces jointes) est confidentiel et peut être privilégié. La distribution ou la divulgation non autorisée de ce courriel est interdite. Sa divulgation à toute personne autre que son destinataire ne constitue pas une renonciation de privilège. Si vous avez reçu ce courriel par erreur, veuillez nous aviser et éliminer ce courriel, ainsi que les pièces jointes, de votre système informatique et de vos dossiers.
Skipped content of type multipart/related
