[mapguide-users] Map Guide Getting Started
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Jun 15 06:29:53 EDT 2009
I'm guessing you downloaded the file with internet explorer,
and have disabled showing known file extensions in windows.
So the file is actually named "Sheboygan.mgp.zip", and it
must be "Sheboygan.mgp". If it appears to have the
correct name, make sure that windows displays known
file extensions.
Regards, Kenneth Skovhede, GEOGRAF A/S
mohammad abdraboh skrev:
> Yes, Zac
> the package directory path is correct
> On Mon, Jun 15, 2009 at 11:54 AM, Zac Spitzer <zac.spitzer at gmail.com
> <mailto:zac.spitzer at gmail.com>> wrote:
>     is the packages directory path correct in server\bin\serverconfig.ini?
>     On Mon, Jun 15, 2009 at 6:40 PM, mohammad
>     abdraboh<mmuslem2002 at gmail.com <mailto:mmuslem2002 at gmail.com>> wrote:
>     > Dear, Spitzer
>     > Thank you for your reply
>     > You are right, I have a mgp in the server\packages directory and
>     tried to
>     > import it with map admin, and the error message was
>     > under the (load package) section, I received (No packages found)
>     > Thank you
>     > Mohammad
>     > _______________________________________________
>     > mapguide-users mailing list
>     > mapguide-users at lists.osgeo.org
>     <mailto:mapguide-users at lists.osgeo.org>
>     > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>     Zac Spitzer -
>     http://zacster.blogspot.com
>     +61 405 847 168
>     mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090615/a503a6cd/attachment.html
