[mapguide-users] MapGuide 2.1 Ok in Studio error Message in IE Impossible to Get Entry Point...
lunab54 lunab54 at free.fr
Mon Jun 15 13:36:22 EDT 2009
Directory Ok => 'C:\Program Files\OSGeo\MapGuide\Server\bin'
i restart iis service and mapguide service and sometimes it's running again
but after zoom or orther it's failed.
when i load the 2.0 package in the 2.1 and just after i open Studio, i saw
that i had a lot of problem data connection invalid.
so i delete it and recreate again and after i can see the map
do you think my problem can come from the package loading ?
Gyufi wrote:
> Try to check the service (mapguide) properties.
> Maybe this shows a wrong directory.
> lunab54 wrote:
>> thanks, but before install MapGuide OSE 2.1, i uninstall 2.0 and delete
>> old folders
>> lunab54 wrote:
>>> Gyufi wrote:
>>>> Hi!
>>>> This happened with me, when I installed MapGuide 2009 and MapGuide 2010
>>>> to the same server.
>>>> I uninstalled the MapGuide 2010.
>>>> Maybe you using another MapGuide API dll, which it can work.
>>>> If you installed more MapGuide to the same server, try to modify port
>>>> numbers in Server\Bin\serverconfig.ini and
>>>> WebServerExtensions\www\webconfig.ini, after then restart each
>>>> services.
>>>> Gyufi
>>>> lunab54 wrote:
>>>>> hi,
>>>>> when i display my weblayout in Studio 2009 it's ok
>>>>> but when i try to display it in IE i get this error message :
>>>>> Impossible Get Entry Point
>>>>> 'CSharp_MgSiteConnectionToMgGuardDisposable' in DLL
>>>>> 'MapGuideUnmanagedApi'.
>>>>> have yo an idea ?
>>>>> thanks
>>>>> Luna
View this message in context: http://n2.nabble.com/MapGuide-2.1-Ok-in-Studio-error-Message-in-IE-Impossible-to-Get-Entry-Point...-tp3080482p3081588.html
