[mapguide-users] MapGuide 2.1 Ok in Studio error Message in IE
Impossible to Get Entry Point...
Gyufi
endre.budai at geoview.hu
Mon Jun 15 14:39:08 EDT 2009
I don't think so, but with MapGuide I can imagine this.
My advice to uninstall everything what belongs to MapGuide, restart the
computer and install MapGuide again.
When it happends with me, it was a mystery.
I didn't find the solution.
I just tried to give you some tip.
Gyufi
lunab54 wrote:
> Directory Ok => 'C:\Program Files\OSGeo\MapGuide\Server\bin'
> i restart iis service and mapguide service and sometimes it's running
> again
> but after zoom or orther it's failed.
> when i load the 2.0 package in the 2.1 and just after i open Studio, i saw
> that i had a lot of problem data connection invalid.
> so i delete it and recreate again and after i can see the map
> do you think my problem can come from the package loading ?
> Gyufi wrote:
>> Try to check the service (mapguide) properties.
>> Maybe this shows a wrong directory.
>> lunab54 wrote:
>>> thanks, but before install MapGuide OSE 2.1, i uninstall 2.0 and delete
>>> old folders
>>> lunab54 wrote:
>>>> Gyufi wrote:
>>>>> Hi!
>>>>> This happened with me, when I installed MapGuide 2009 and MapGuide
>>>>> 2010 to the same server.
>>>>> I uninstalled the MapGuide 2010.
>>>>> Maybe you using another MapGuide API dll, which it can work.
>>>>> If you installed more MapGuide to the same server, try to modify port
>>>>> numbers in Server\Bin\serverconfig.ini and
>>>>> WebServerExtensions\www\webconfig.ini, after then restart each
>>>>> services.
>>>>> Gyufi
>>>>> lunab54 wrote:
>>>>>> hi,
>>>>>> when i display my weblayout in Studio 2009 it's ok
>>>>>> but when i try to display it in IE i get this error message :
>>>>>> Impossible Get Entry Point
>>>>>> 'CSharp_MgSiteConnectionToMgGuardDisposable' in DLL
>>>>>> 'MapGuideUnmanagedApi'.
>>>>>> have yo an idea ?
>>>>>> thanks
>>>>>> Luna
View this message in context: http://n2.nabble.com/MapGuide-2.1-Ok-in-Studio-error-Message-in-IE-Impossible-to-Get-Entry-Point...-tp3080482p3082009.html
