[mapguide-users] more 2.1 problems (GDAL this time)
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Jun 16 02:37:47 EDT 2009
Are you using a single file or a folder?
I remember having trouble with OGR, because the alias substitution ends
with a backslash,
and the OGR provider chokes on it.
Do you have the same setup on the test and production server?
Could you send the xml for the featuresource?
Regards, Kenneth Skovhede, GEOGRAF A/S
Andrew DeMerchant skrev:
> The alias is now pointing to the C drive (local), since mapped drives
> was not working. The alias is fine, for sure - I see the files inside
> of the alias from within Maestro, as well as EnumerateUnmanagedData.
> Andrew
> On 6/15/2009 3:27 PM, Jason Birch wrote:
>> Andrew,
>> What path is the alias pointing to? Have you restarted the server
>> since changing to UNCs?
>> Jason
>> *From:* Andrew DeMerchant
>> *Sent:* Monday, June 15, 2009 11:01 AM
>> *To:* MapGuide Users Mail List
>> *Subject:* Re: [mapguide-users] more 2.1 problems (GDAL this time)
>> I just checked with 2.0.2 and I get the same results. Seems like it
>> doesn't need to make one in order to work. Any other thoughts? I'm
>> still unable to get this working...
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
Skipped content of type multipart/related
