[mapguide-users] more 2.1 problems (GDAL this time)
Andrew DeMerchant andrew.demerchant at gemtec.ca
Tue Jun 16 08:26:15 EDT 2009
It's a folder....but I can't make a single file work either. I've also
just tried it on a new server install (Windows Server 2008 - vs 2000) -
same thing. I've tried with and without the backslash - no change.
Here's the xml:
<?xml version="1.0" encoding="utf-8"?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
<Provider>OSGeo.Gdal</Provider>
<Parameter>
<Name>DefaultRasterFileLocation</Name>
<Value>%MG_DATA_PATH_ALIAS[435989]%air_photos/</Value>
</Parameter>
<SupplementalSpatialContextInfo>
<Name>unnamed</Name>
<CoordinateSystem>PROJCS["CANST-NB83-CSRS",GEOGCS["LL-CSRS",DATUM["CSRS",SPHEROID["GRS1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Oblique_Stereographic"],PARAMETER["false_easting",2500000.000],PARAMETER["false_northing",7500000.000],PARAMETER["latitude_of_origin",46.50000000000000],PARAMETER["central_meridian",-66.50000000000000],PARAMETER["scale_factor",0.999912000000],UNIT["Meter",1.00000000000000]]</CoordinateSystem>
</SupplementalSpatialContextInfo>
</FeatureSource>
Andrew
On 6/16/2009 3:37 AM, Kenneth Skovhede, GEOGRAF A/S wrote:
> Are you using a single file or a folder?
> I remember having trouble with OGR, because the alias substitution
> ends with a backslash,
> and the OGR provider chokes on it.
> Do you have the same setup on the test and production server?
> Could you send the xml for the featuresource?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Andrew DeMerchant skrev:
>> The alias is now pointing to the C drive (local), since mapped drives
>> was not working. The alias is fine, for sure - I see the files inside
>> of the alias from within Maestro, as well as EnumerateUnmanagedData.
>> Andrew
>> On 6/15/2009 3:27 PM, Jason Birch wrote:
>>> Andrew,
>>> What path is the alias pointing to?  Have you restarted the server
>>> since changing to UNCs?
>>> Jason
>>> *From:* Andrew DeMerchant
>>> *Sent:* Monday, June 15, 2009 11:01 AM
>>> *To:* MapGuide Users Mail List
>>> *Subject:* Re: [mapguide-users] more 2.1 problems (GDAL this time)
>>> I just checked with 2.0.2 and I get the same results. Seems like it
>>> doesn't need to make one in order to work. Any other thoughts? I'm
>>> still unable to get this working...
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> 	*Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
