[mapguide-users] Error when selecting features
Mike Adair madair at dmsolutions.ca
Tue Jun 16 08:55:02 EDT 2009
That error message is misleading because it is saying it can't parse a
JSON response.  To find the real cause of the error, you will have to
look in Firebug at the response from the queries sent to MapGuide, which
will be in one of SaveSelection.php, GetSelection.php or Selection.php
(maybe even Query.php) depending on what version you are using.
Mike
Adam Brooks wrote:
> Hello,
> I'm new to Mapguide, using Mapguide 2009 Enterprise version 2.0, I've
> authored my first map (a fairly simple map that has a few layers of
> infrastructure that calls some attributes from a MySQL database that is
> also hosted on the same server).  4 of 5 featuresources work properly (I
> can select them, and launch their links to each feature's DB record.
> When I try and select features out of the fifth featuresource I get the
> following error:
> Fusion Error:
> WARNING: Exception occurred in AJAX callback.
> SyntaxError: missing ; before statement
> Location: undefined (735)
> xx)
> I don't know enough about fusion to understand what is causing this
> Error.  Can anyone lend some insight as to why I receive this message
> and what I may be able to do to correct it? Or where I could turn to
> further investigate the problem?
> Thanks in advance,
> Adam Brooks
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
