[mapguide-users] Error when selecting features
Adam Brooks abrooks at uemconsulting.com
Tue Jun 16 08:41:25 EDT 2009
Hello,
I'm new to Mapguide, using Mapguide 2009 Enterprise version 2.0, I've
authored my first map (a fairly simple map that has a few layers of
infrastructure that calls some attributes from a MySQL database that is
also hosted on the same server).  4 of 5 featuresources work properly (I
can select them, and launch their links to each feature's DB record.
When I try and select features out of the fifth featuresource I get the
following error:
Fusion Error:
WARNING: Exception occurred in AJAX callback.
SyntaxError: missing ; before statement
xx)
I don't know enough about fusion to understand what is causing this
Error.  Can anyone lend some insight as to why I receive this message
and what I may be able to do to correct it? Or where I could turn to
further investigate the problem?
Thanks in advance,
Adam Brooks
