[mapguide-users] Map Versioning
Haris Kurtagic
haris at sl-king.com
Tue Jun 16 15:46:24 EDT 2009
King.Oracle doesn't have direct support for Oracle Versioning.
Versioning in Oracle is done transparent to application and you can use
it even with King.Oracle by switching workspaces with SQL statements.
I have worked with Oracle versioning quite a lot and in my experience it
is much more effort in how to support business processes with versioned
data. Just to enable versioning of data is very straightforward in
Oracle.
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Martin
Morrison
Sent: Tuesday, June 16, 2009 9:03 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Map Versioning
Let's see if I can take another hack at this.
Mapguide was developed as a web-enabled map reader tool (with limited
redlining) not as a full-blown map editing tool. ARCGis is a map
editing tool.
Mapguide OS is free (MGE costs for support). ARCGis costs a significant
amount of money for many users.
Mapguide consists of basically 3 software pieces/technologies that you
need to be aware of.
1) Mapguide.
2) FDO.
3) Datastorage (either database or file-based)
Each of the software pieces will have to accommodate versioning in order
for it to work. As a side note, ESRI's ARCGis does NOT do versioning on
it's own. It relies on Oracle (which has versioning builtin).
The challenge is:
Mapguide has no concept of what you are trying to do. You would need to
develop, write and test from scratch. I don't think anybody has done
this. (someone please correct me if I am wrong)
FDO **MIGHT** understand it if the FDO provider was written to support
it.
The only two databases that I'm aware of that support true versioning is
Oracle and Smallworld's VMDS. Both are expensive. Smallworld is not
really an option here, since you must use Mapguide Enterprise in order
to have the FDO provider for it. So that leaves you with Oracle. I
believe that Autodesk's proprietary Oracle FDO provider may have
versioning, you will be legally required to purchase and use Mapguide
Enterprise though. I don't think King Oracle has versioning built-in
(Haris can you confirm/deny).
So where are we?
If you are wanting true versioning of data, I suspect you are wanting to
use Mapguide as an editing tool to avoid buying licenses for each user.
It was not designed to do that. I strongly suggest that you use a tool
truly designed for editing data.
If you are wanting to see a history of data changes, copy each
day/week/month data to a new dataset and let the user switch between
datasets. This is a matter of writing code to allow the user to change
the base map or to allow the user to switch a layer. This would not be
generic code for Mapguide, it would be specific to your application.
You will need to write this, there are some people on here that can help
with specific questions relating to this.
If you are simply wanting the users to see redlines or not, than make
sure you add them to a separate layer and allow the user them off and on
at will.
Thanks,
Martin
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ivan
Milicevic
Sent: Tuesday, June 16, 2009 9:56 AM
Martin Morrison replyed on this topic few days ago. Why do you repost it
again?
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of sathishpsk9
Sent: Tuesday, June 16, 2009 1:45 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Map Versioning
Hi all,
I need to implement map versiong concept...any body here has ever
worked on this before ?
Can i get any help or even suggestions ? Last night i gone through the
white
paper of ARCGIS .. Versioning , i understood that it is more of database
thing than programming .......Can anybody throw some light on this
concept?
Thanks & Regards,
Satish
View this message in context:
http://n2.nabble.com/Map-Versioning-tp3085824p3085824.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
