[mapguide-users] Map Versioning
Johannes Schulte Südhoff johannes_schulte_sudhoff at yahoo.se
Tue Jun 16 16:03:27 EDT 2009
Hi
AFAIK the FDO ArcSDE provider supports versioning, so why not just use it with ArcSDE?
> versioning in order for it to work.  As a side note,
> ESRI's ARCGis does NOT do versioning on it's own.  It
> relies on Oracle (which has versioning builtin).
I thought ESRI is doing its own versioning, are you sure about this?
Regards Johannes
      __________________________________________________________
Går det långsamt? Skaffa dig en snabbare bredbandsuppkoppling.
Sök och jämför priser hos Kelkoo.
http://www.kelkoo.se/c-100015813-bredband.html?partnerId=96914325
