[mapguide-users] Map Versioning
Martin Morrison
martin.morrison at edsi.com
Tue Jun 16 16:14:32 EDT 2009
You do realize that ArcSDE runs on top of Oracle don't you? Also the question was ArcGIS not ArcSDE, two different products...
Martin
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Johannes Schulte Südhoff
Sent: Tuesday, June 16, 2009 4:03 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Map Versioning
Hi
AFAIK the FDO ArcSDE provider supports versioning, so why not just use it with ArcSDE?
> versioning in order for it to work. As a side note,
> ESRI's ARCGis does NOT do versioning on it's own. It
> relies on Oracle (which has versioning builtin).
I thought ESRI is doing its own versioning, are you sure about this?
Regards Johannes
__________________________________________________________
Går det långsamt? Skaffa dig en snabbare bredbandsuppkoppling.
Sök och jämför priser hos Kelkoo.
http://www.kelkoo.se/c-100015813-bredband.html?partnerId=96914325
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
