[mapguide-users] Mapguide Crashing IIS (w3wp.exe) service or vice Versa
Andy Morsell amorsell at spatialgis.com
Wed Jun 17 19:50:23 EDT 2009
I get a similar error message on Windows 2003 Server and MGOS 2.0.2.
Usually upon login in I'll have several console messages about w3wp.exe
error messages and sometimes the IIS Worker Process.  But, it's never been
fatal for me and MapGuide still ticks along (has been for about two months
without one restart) so I've ignored it for the most part.
I do have the raster patch described in this thread implemented, however.
Maybe that would help your problems.
http://n2.nabble.com/FDO-Gdal-raster-problem-tp2538452p2542802.html
Andy Morsell, P.E.
Spatial Integrators, Inc.
509-466-3959
www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Tony
Sent: Wednesday, June 17, 2009 10:48 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Mapguide Crashing IIS (w3wp.exe) service or
vice Versa
Hi
i have the same issue with win2003 server sp2. and mge 2009
anyone has a clue. i thought my installation or server has issue so i got
fresh server and did new installation and the problem was there.  i think we
should have ticket for this issue ??
tony
Flipper wrote:
> Keep getting this error(See Below) on one specific machine on a regular
> basis...couldnt tell you whats different on this install from others...its
> Windows 2003 Server SP2...Anyone have any ideas?
> Application Errors:
> Event Type:     Error
> Event Source:   Application Error
> Event Category: (100)
> Event ID:       1000
> Date:           3/2/2009
> Time:           10:58:23 AM
> User:           N/A
> Computer:       SERVERNAME1
> Description:
> Faulting application w3wp.exe, version 6.0.3790.3959, faulting module
> isapi_MapAgent.dll, version 2.0.2.3402, fault address 0x00001cf4.
> For more information, see Help and Support Center at
> http://go.microsoft.com/fwlink/events.asp.
> Data:
> 0000: 41 70 70 6c 69 63 61 74   Applicat
> 0008: 69 6f 6e 20 46 61 69 6c   ion Fail
> 0010: 75 72 65 20 20 77 33 77   ure  w3w
> 0018: 70 2e 65 78 65 20 36 2e   p.exe 6.
> 0020: 30 2e 33 37 39 30 2e 33   0.3790.3
> 0028: 39 35 39 20 69 6e 20 69   959 in i
> 0030: 73 61 70 69 5f 4d 61 70   sapi_Map
> 0038: 41 67 65 6e 74 2e 64 6c   Agent.dl
> 0040: 6c 20 32 2e 30 2e 32 2e   l 2.0.2.
> 0048: 33 34 30 32 20 61 74 20   3402 at
> 0050: 6f 66 66 73 65 74 20 30   offset 0
> 0058: 30 30 30 31 63 66 34      0001cf4
> Event Type:     Error
> Event ID:       1000
> Date:           3/2/2009
> Time:           10:58:20 AM
> User:           N/A
> Description:
> Data:
> Event Type:     Error
> Event ID:       1000
> Date:           3/2/2009
> Time:           10:58:17 AM
> User:           N/A
> Description:
> Data:
> Event Type:     Error
> Event ID:       1000
> Date:           3/2/2009
> Time:           10:58:14 AM
> User:           N/A
> Description:
> Data:
> Event Type:     Error
> Event ID:       1000
> Date:           3/2/2009
> Time:           10:58:08 AM
> User:           N/A
> Description:
> Data:
> System Errors:
> Event Type:     Warning
> Event Source:   W3SVC
> Event Category: None
> Event ID:       1011
> Date:           3/2/2009
> Time:           10:58:10 AM
> User:           N/A
> Description:
> A process serving application pool 'MapGuide' suffered a fatal
> communication error with the World Wide Web Publishing Service. The
> process id was '4140'. The data field contains the error number.
> Data:
> 0000: 6d 00 07 80               m..?
> Event Type:     Warning
> Event Source:   W3SVC
> Event ID:       1009
> Date:           3/2/2009
> Time:           10:58:14 AM
> User:           N/A
> Description:
> A process serving application pool 'MapGuide' terminated unexpectedly. The
> process id was '2264'. The process exit code was '0xc0000005'.
> Event Type:     Warning
> Event Source:   W3SVC
> Event ID:       1011
> Date:           3/2/2009
> Time:           10:58:17 AM
> User:           N/A
> Description:
> process id was '6328'. The data field contains the error number.
> Data:
> Event Type:     Warning
> Event Source:   W3SVC
> Event ID:       1011
> Date:           3/2/2009
> Time:           10:58:20 AM
> User:           N/A
> Description:
> process id was '2988'. The data field contains the error number.
> Data:
> Event Type:     Warning
> Event Source:   W3SVC
> Event ID:       1011
> Date:           3/2/2009
> Time:           10:58:24 AM
> User:           N/A
> Description:
> process id was '6244'. The data field contains the error number.
> Data:
> Event Type:     Error
> Event Source:   W3SVC
> Event ID:       1002
> Date:           3/2/2009
> Time:           10:58:24 AM
> User:           N/A
> Description:
> Application pool 'MapGuide' is being automatically disabled due to a
> series of failures in the process(es) serving that application pool.
View this message in context:
http://n2.nabble.com/Mapguide-Crashing-IIS-%28w3wp.exe%29-service-or-vice-Ve
rsa-tp2411452p3094352.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
