[mapguide-users] Mapguide Crashing IIS (w3wp.exe) service or vice Versa
Tony techswami at hotmail.com
Wed Jun 17 13:48:08 EDT 2009
Hi
i have the same issue with win2003 server sp2. and mge 2009
anyone has a clue. i thought my installation or server has issue so i got
fresh server and did new installation and the problem was there.  i think we
should have ticket for this issue ??
tony
Flipper wrote:
> Keep getting this error(See Below) on one specific machine on a regular
> basis...couldnt tell you whats different on this install from others...its
> Windows 2003 Server SP2...Anyone have any ideas?
> Application Errors:
> Event Type:     Error
> Event Source:   Application Error
> Event Category: (100)
> Event ID:       1000
> Date:           3/2/2009
> Time:           10:58:23 AM
> User:           N/A
> Computer:       SERVERNAME1
> Description:
> Faulting application w3wp.exe, version 6.0.3790.3959, faulting module
> isapi_MapAgent.dll, version 2.0.2.3402, fault address 0x00001cf4.
> For more information, see Help and Support Center at
> http://go.microsoft.com/fwlink/events.asp.
> Data:
> 0000: 41 70 70 6c 69 63 61 74   Applicat
> 0008: 69 6f 6e 20 46 61 69 6c   ion Fail
> 0010: 75 72 65 20 20 77 33 77   ure  w3w
> 0018: 70 2e 65 78 65 20 36 2e   p.exe 6.
> 0020: 30 2e 33 37 39 30 2e 33   0.3790.3
> 0028: 39 35 39 20 69 6e 20 69   959 in i
> 0030: 73 61 70 69 5f 4d 61 70   sapi_Map
> 0038: 41 67 65 6e 74 2e 64 6c   Agent.dl
> 0040: 6c 20 32 2e 30 2e 32 2e   l 2.0.2.
> 0048: 33 34 30 32 20 61 74 20   3402 at
> 0050: 6f 66 66 73 65 74 20 30   offset 0
> 0058: 30 30 30 31 63 66 34      0001cf4
> Event Type:     Error
> Event ID:       1000
> Date:           3/2/2009
> Time:           10:58:20 AM
> User:           N/A
> Description:
> Data:
> Event Type:     Error
> Event ID:       1000
> Date:           3/2/2009
> Time:           10:58:17 AM
> User:           N/A
> Description:
> Data:
> Event Type:     Error
> Event ID:       1000
> Date:           3/2/2009
> Time:           10:58:14 AM
> User:           N/A
> Description:
> Data:
> Event Type:     Error
> Event ID:       1000
> Date:           3/2/2009
> Time:           10:58:08 AM
> User:           N/A
> Description:
> Data:
> System Errors:
> Event Type:     Warning
> Event Source:   W3SVC
> Event Category: None
> Event ID:       1011
> Date:           3/2/2009
> Time:           10:58:10 AM
> User:           N/A
> Description:
> A process serving application pool 'MapGuide' suffered a fatal
> communication error with the World Wide Web Publishing Service. The
> process id was '4140'. The data field contains the error number.
> Data:
> 0000: 6d 00 07 80               m..?
> Event Type:     Warning
> Event Source:   W3SVC
> Event ID:       1009
> Date:           3/2/2009
> Time:           10:58:14 AM
> User:           N/A
> Description:
> A process serving application pool 'MapGuide' terminated unexpectedly. The
> process id was '2264'. The process exit code was '0xc0000005'.
> Event Type:     Warning
> Event Source:   W3SVC
> Event ID:       1011
> Date:           3/2/2009
> Time:           10:58:17 AM
> User:           N/A
> Description:
> process id was '6328'. The data field contains the error number.
> Data:
> Event Type:     Warning
> Event Source:   W3SVC
> Event ID:       1011
> Date:           3/2/2009
> Time:           10:58:20 AM
> User:           N/A
> Description:
> process id was '2988'. The data field contains the error number.
> Data:
> Event Type:     Warning
> Event Source:   W3SVC
> Event ID:       1011
> Date:           3/2/2009
> Time:           10:58:24 AM
> User:           N/A
> Description:
> process id was '6244'. The data field contains the error number.
> Data:
> Event Type:     Error
> Event Source:   W3SVC
> Event ID:       1002
> Date:           3/2/2009
> Time:           10:58:24 AM
> User:           N/A
> Description:
> Application pool 'MapGuide' is being automatically disabled due to a
> series of failures in the process(es) serving that application pool.
View this message in context: http://n2.nabble.com/Mapguide-Crashing-IIS-%28w3wp.exe%29-service-or-vice-Versa-tp2411452p3094352.html
