[mapguide-users] RE: GDAL FDO Issues
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Wed Jun 17 21:07:22 EDT 2009
I've been trying to make the gdal work for 2.1 for a week or 2 now, with
the help of this group.....but still no go.
Andrew
Mark Nichols wrote:
> Still is not working. I'll step through the instructions again and make
> sure I'm doing it right.
> Anything else that could have changed. What about the world file. I have a
> folder with the sid and the sdw.
> I re-created the data connection and layer, still nothing showing.
> Mark Nichols
> markn at spicergroup.com
> On 6/17/09 7:41 PM, "Jason Birch" <Jason.Birch at nanaimo.ca> wrote:
>> Are you using the new MrSID plugin referenced in this post?
>> http://n2.nabble.com/ECWs-and-MG-2.1-tp2978248p2978703.html
>> If this works for you and you have time, it would be awesome if you could add
>> it to the FDO wiki. I haven't had a chance yet:
>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
>> Jason
>> -----Original Message-----
>> From: Nichols, Mark A.
>> Sent: Wednesday, June 17, 2009 4:16 PM
>> Subject: [mapguide-users] GDAL FDO Issues
>> I'm working with MGOS 2.1. I did have my sid's working in 2.0 but no longer
>> when I upgraded.
>> Yes, the coordinate system on the data does match that of the map. I turned
>> on the debugging but don't see anything new in the log.
>> I think that I may have my files in a wrong locaton. Here's my file
>> structure:
>> Server\bin
>> Server\FDO
>> Server\gdalplugins
>> Server\gdalplugins\gdal_ECW.dll
>> Server\gdalplugins\gdal_MrSID.dll
>> Does this look good so far?
>> Any suggestions?
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Mark Nichols
> Project Manager
> Spicer Group, Inc.
> 230 S. Washington Avenue
> Saginaw, MI 48607
> Phone: (989) 754-4717
> Fax: (989) 754-4440
> mailto: markn at spicergroup.com
> www.spicergroup.com
> Stronger. Safer. Smarter. Spicer
