[mapguide-users] RE: GDAL FDO Issues
Mark Nichols
markn at spicergroup.com
Wed Jun 17 21:19:58 EDT 2009
Andrew, What size files are you using? Mine are < 600 MB. Does size
matter. Most likely I have something out of place, just can't find what.
Mark
On 6/17/09 9:07 PM, "Andrew DeMerchant" <andrew.demerchant at gemtec.ca> wrote:
> I've been trying to make the gdal work for 2.1 for a week or 2 now, with
> the help of this group.....but still no go.
> Andrew
> Mark Nichols wrote:
>> Still is not working. I'll step through the instructions again and make
>> sure I'm doing it right.
>> Anything else that could have changed. What about the world file. I have a
>> folder with the sid and the sdw.
>> I re-created the data connection and layer, still nothing showing.
>> Mark Nichols
>> On 6/17/09 7:41 PM, "Jason Birch" <Jason.Birch at nanaimo.ca> wrote:
>>> Are you using the new MrSID plugin referenced in this post?
>>> http://n2.nabble.com/ECWs-and-MG-2.1-tp2978248p2978703.html
>>> If this works for you and you have time, it would be awesome if you could
>>> add
>>> it to the FDO wiki. I haven't had a chance yet:
>>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
>>> Jason
>>> -----Original Message-----
>>> From: Nichols, Mark A.
>>> Sent: Wednesday, June 17, 2009 4:16 PM
>>> Subject: [mapguide-users] GDAL FDO Issues
>>> I'm working with MGOS 2.1. I did have my sid's working in 2.0 but no longer
>>> when I upgraded.
>>> Yes, the coordinate system on the data does match that of the map. I turned
>>> on the debugging but don't see anything new in the log.
>>> I think that I may have my files in a wrong locaton. Here's my file
>>> structure:
>>> Server\bin
>>> Server\FDO
>>> Server\gdalplugins
>>> Server\gdalplugins\gdal_ECW.dll
>>> Server\gdalplugins\gdal_MrSID.dll
>>> Does this look good so far?
>>> Any suggestions?
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Mark Nichols
>> Project Manager
>> Spicer Group, Inc.
>> 230 S. Washington Avenue
>> Saginaw, MI 48607
>> Phone: (989) 754-4717
>> Fax: (989) 754-4440
>> mailto: markn at spicergroup.com
>> www.spicergroup.com
>> Stronger. Safer. Smarter. Spicer
Mark Nichols
Project Manager
Spicer Group, Inc.
Saginaw, MI 48607
Fax: (989) 754-4440
www.spicergroup.com
